Author Topic: M42 vacuum lines??????????????  (Read 12271 times)
1991 318is
« on: August 07, 2007, 10:13:33 PM »
hey need some help redoing all of them some were not in the right spot some clogged some cracked, all from previous owner. This is the problem, on the bottom of the air intake pipe from the filter box to the TB there are 2 90deg elbows i know where one goes but not the seconded one. What goes on this elbow in the pic and what does it come from?
« Reply #1 on: August 07, 2007, 10:23:01 PM »
There should be a line coming from the front of the valve cover.
Wise Old Dog
« Reply #2 on: August 07, 2007, 11:01:02 PM »
IIRC there is only 1 hose running to the bottom of the breather elbow. There should be a plug installed in the hole you are showing, not an elbow. The hose from the valve cover runs to the throttle body, and the idle air hose runs to the breather elbow.
« Reply #3 on: August 07, 2007, 11:57:36 PM »
The 90 degree elbow is supposed to be there. It connects to the hose coming off the left front of the valve cover.
http://www.m42club.com/forums/showthread.php?t=2742&highlight=mess+intake
Wise Old Dog
« Reply #4 on: August 08, 2007, 06:03:32 AM »
That is the diagram for your cooling hoses. There is only 1 hose connected to the breather elbow. It is the idle air hose. It is not shown on this diagram. The hose from the front of the valve cover goes to the throttle body.
« Reply #5 on: August 08, 2007, 10:34:39 AM »
He is right. I was trying to point out that all the leaking vacuum hoses connect to the cooling system in one way or another and its impossible to figure out where everything goes until you take apart your cooling system.
1991 318is
« Reply #6 on: August 08, 2007, 04:33:02 PM »
ya i have the upper part of my manifold off ordered like 11 hoses today. so the elbows on the bottom of the intake hose goes too/ on to what?
« Last Edit: August 08, 2007, 04:42:11 PM by 1991 318is »
« Reply #7 on: August 08, 2007, 06:00:11 PM »
Here's the composite of all the hoses. I forget where I saw it but saved for reference.
http://www.m42club.com/forums/showthread.php?t=3397
Question mark goes to charcoal cannister
Wise Old Dog
« Reply #8 on: August 08, 2007, 06:00:36 PM »
You are missing the plug that goes into the inboard hole. Only one plastic elbow is needed. It is connected to the last hose that is in the series of hoses that originates from the idle control valve. I think there are only 2 hoses in series that run from the idle air valve to the intake hose. D. Clay's drawing is exactly correct, although it does not show the plug on the intake boot. I have an extra if you need it.
« Last Edit: August 08, 2007, 06:12:47 PM by Wise Old Dog »
1991 318is
« Reply #9 on: August 10, 2007, 02:11:39 PM »
so i just need to plug that hole on the elbow on the intake tube?
e9nine
« Reply #10 on: August 10, 2007, 02:25:51 PM »
Quote from: 1991 318is;31387
Plug the boot. Even though there are 2 ports, you only use one along with the 90 degree elbow to point it the right way towards the ICV hose.
1991 318is
« Reply #11 on: August 10, 2007, 09:36:38 PM »
ok ill plug it when it goes back together i order the parts so I'm waiting for them now.
1991 E30 M42
« Reply #12 on: August 10, 2007, 11:10:43 PM »
here are the hoses under the manifold
