i think thats an error? at least the connectors are different arent they?
Well, I thought it was an error as well, initially. I was looking through realoem and saw that there was a coil-to-plug boot in the ignition ciol diagram for the M42. Pelican Parts' picture of the S50 coil was strikingly familiar looking...so i cross referenced the PN's & sure enough, same PN on the different vehicles. Not only that, but when you do a search for the PN for the boot, the part is listed for the 318iS.
If you search Pelican in the root BMW level, it will shot the result as an E36 part, but if you click on the part, it goes into the E30 section & is titled a part for the E30. I just ordered new valve cover gaskets and 4 plug boots. I also informed them of the discrepancy.
I guess I just have to go get a set of helicoil inserts to repair the like 9 stripped valve cover bolt holes in the head, and I am all set!
