Author Topic: Coil On plug retrofit  (Read 25952 times)
2002maniac
« Reply #60 on: June 16, 2006, 05:45:27 PM »
there is a fat ground wire going to each coil through the harness.
« Reply #61 on: June 16, 2006, 07:44:28 PM »
Quote from: 2002maniac
Yes, but it connects to the coils inside the package, and does not touch the iron core/slats.  I was just worried about whether the core needed to be grounded.  Seems to be a no, but I may do something anyway, JIC.
Warning, long:
Well, there are 3 wires.  They are all the same size (according to Chilton), and are as follows:
Pin 1)  1mm core Black.  This is the negative side of the primary coil, and is grounded momentarily only when the motronic grounds it through a switching transistor.  The rest of the time it sits at 12V because of: Pin 3
Pin 3)  This is a 1mm core Green wire that is directly connected to the 12V supply switched by the key/ignition switch.  It is the positive side of the primary coil.
Pin 2)  This is a 1mm core Brown/Orange wire.  It connects the secondary coil to the ground distribution point.  The secondary has neither a positive nor a negative side in this application.  Two sparks are actually made upon each ignition event triggered by the Motronic.  Each one going in the opposite direction, one after the other.  This is from the generation of the magnetic field in the ferrous core upon the grounding of the primary coil (creating a current in one direction), then the immediate collapse of that field when the ground is cut off again, stopping the current flow in the primary, and causing a current in the secondary moving in the opposite direction.
Grounds.
« Reply #62 on: June 16, 2006, 10:31:42 PM »
My question was prompted by the following:
With the wires detached and placed slightly out of the way, you can now remove each of the six coils.  Each coil is fastened to the valve cover using two screws.  On two of the coils, there are two small ground straps that connect the coil to the stud on the cylinder head.  Take note of these ground straps - they must be installed properly when you are finished, otherwise your car may encounter problems.  These two ground straps are shown marked by the greens arrow in Figure 8 and Figure 9 (coil already removed in this photo).
Complete article here:
http://www.pelicanparts.com/bmw/techarticles/E36-Spark-Plugs/E36-Spark-Plugs.htm
The M42 coils may be grounded to the fender apron. My E36 manual shows the same setup with the coils connected with thin metal pieces and one ground wire to a motor bracket. The piece is #10 in the realoem drawing below. If this is unnecessary so much the better.
« Reply #63 on: June 16, 2006, 11:28:43 PM »
Hmmm.  Well, I guess to be safe I will make sure they are all grounded.
EDIT:
I was a little vored & modeled the plug boots as well.  At least now I have some good dimensioned data to use for future stuff.  Have fun.
More detail then it probably needed.
http://www.e30tuner.com/coilonplug/bmw006.jpg
I even decal'ed it.  Good practice.
http://www.e30tuner.com/coilonplug/bmw007.jpg
And here it is, where it belongs.
http://www.e30tuner.com/coilonplug/bmw008.jpg
« Last Edit: June 17, 2006, 01:49:00 AM by bmwman91 »
