afm
Author Topic: afm  (Read 3186 times)
logger
afm
« on: July 25, 2007, 01:41:31 PM »
How much can adjust the spring in the afm ?
Shocker
afm
« Reply #1 on: July 25, 2007, 06:45:58 PM »
You dont want to mess with the spring it will just make you car run worse.  Why do you want to modify it?
logger
afm
« Reply #2 on: July 25, 2007, 09:09:59 PM »
problems with car not running right check my thread a few threads down .  After messing with this it has seemed to help ?????
badboypolar
afm
« Reply #3 on: July 25, 2007, 11:35:14 PM »
I had the same problem you are having. I bought a rebuilt one from pelican. It's like driving a brand new car.
Save yourself the headache and buy a new, well rebuilt, unit.
Shocker
afm
« Reply #4 on: July 26, 2007, 12:02:52 AM »
Quote from: badboypolar;30423
If your going to get a new AFM at least check into a MAF conversion.
badboypolar
afm
« Reply #5 on: July 26, 2007, 09:44:58 AM »
Well I can't because I prepping for SpecE30 and the MAF conversion isn't allowed.
afm
« Reply #6 on: July 26, 2007, 11:49:39 PM »
Look into a rebuilt one at Pelican.  $180 for it...a MAF conversion will run you considerably more.  No power gains to be had either, though driveability improves greatly.
Shocker
afm
« Reply #7 on: July 27, 2007, 12:13:50 AM »
Quote from: bmwman91;30509
That depends on if your running boost.  The Stock AFM is great on a Stock motor but it does restrict if you’re running over 12 psi.
afm
« Reply #8 on: July 27, 2007, 05:40:36 PM »
Indeed.  Can the stock AFM even give a useful output above like 7psi of boost?
