Skid Plates
Author Topic: Skid Plates  (Read 9869 times)
teh Phil
Skid Plates
« on: July 22, 2007, 02:13:58 AM »
From what I've read, there are two skid plates that I think can be used with our cars. The custom 666 fabrication plate, and the OEM skid plate (Does anyone know for sure if this will fit?) I'm hoping someone may be able to shed some light on a few of my concerns.....
-How much does the OEM plate weigh? IIRC, 666's was going to weigh 3-4 lbs.
-How does the 666 aluminum hold up? Could it be easily damaged?
-Does the 666 plate cause any fluctuation in oil temps? I figure trapping all of that hot air up there can't be good. It doesn't look like this plate breathes very well.
318iSdaniel
Skid Plates
« Reply #1 on: July 22, 2007, 12:22:13 PM »
there is another thread around here about skidplates, and iirc the OEM plate does not fit because the m42 oil pan is shaped differently than the m20.
Skid Plates
« Reply #2 on: July 22, 2007, 05:18:10 PM »
Hmm. I was under the impression that the OEM one fit fine. Nonetheless, I have a 666 one on, and don't seem to have any problems with heat buildup. I can't speak to the durability - even with a skidplate, I try not to hit anything. :) It is pretty thick, but it is also only aluminum, so it's not going to take the full brunt of a manhole cover at speed.
AL GReeNeRy
Skid Plates
« Reply #3 on: July 22, 2007, 09:26:15 PM »
Quote from: ak96ss;30133
any protection is better than none. any pics?
1991 318is : brilliantrot
teh Phil
Skid Plates
« Reply #4 on: July 22, 2007, 09:51:49 PM »
Quote from: 318iSdaniel;30122
I found a few threads, but I think all I found was that someone had ordered the OEM one, I never heard anything about fitment or saw any pictures. I'm still curious about the heat buildup/durability of the 666 plate.
Hah, this is true. thanks for the info.
Quote from: AL GReeNeRy;30137
http://www.666fab.com/skidplateinstall.html
Abrax
560 km in 3 hours and 5 minutes completely legal!!!                  I love german highroads!!!
Abrax
Skid Plates
« Reply #6 on: July 23, 2007, 03:13:52 PM »
It is pretty durable - some serious damage avoided :-)
It is like that, becauce the car usually slides over a rock or anything.
Hot oil, right - after installing it You should put oilcooler there too...
Weight - about 6-8 kilos all.
Material: Alluminium PA11 6mm thickness.
The best would be PA6 5mm...
Master
Skid Plates
« Reply #7 on: July 23, 2007, 04:05:07 PM »
I've seen a e36 cross brace installed into a e30, should function like a skid pad + extra body rigidity
"Brake, heel and toe, brake, gas…" - The Drift formula.
Selling a unique e30 rear spoiler, good condition, see here
PumpItUp
Boris3
Skid Plates
« Reply #9 on: November 24, 2013, 07:33:18 AM »
Red46 sump armor
http://www.red46.net/store/p6/Sump_Armor_-_BMW_e30.html
$160 shipped, now on sale @ $140.
Just installed one on my 1991 318is beater. I have the race skids plate on the Spec E30.
colin86325
Re: Skid Plates
« Reply #10 on: November 25, 2013, 07:25:05 AM »
I've seen quite a few failed Raceskids plates but I haven't heard of any of the HIK/E30 Motorwerks plates failing.
PumpItUp
Re: Skid Plates
« Reply #11 on: November 26, 2013, 05:12:07 AM »
Failed in what way? It looks overpriced but a little more protective than the factory option. Red46 looks like a good deal, hope it's quality. Maybe modifying plates (making oil-plug holes) sold for other bmws is the answer.
http://www.ecstuning.com/Search/SiteSearch/Skid_Plate/ES127809/ (325ix)
http://www.ecstuning.com/Search/SiteSearch/Skid_Plate/ES127908/ (m3)
And e36 cross braces!?
colin86325
Re: Skid Plates
« Reply #12 on: November 26, 2013, 06:40:50 AM »
I have just seen 5-6 instances where somebody hit something and cracked their oil pan.  I haven't checked in the past year or two, but I imagine there are even more cases now.
Obviously these people came into contact with a stationary object, but if you just want protection from gravel and sticks it will be more than sufficient.
keflaman
  • -Receive: 35
Re: Skid Plates
« Reply #13 on: November 26, 2013, 04:56:21 PM »
I drove over a dead raccoon yesterday...a really, really big raccoon. Made a hell of a noise as it bounced between the road and my floorboards. No damage noted.
If I'd had that stock BMW skid plate I would have skewered the coon.
