Pictures af my project
Author Topic: Pictures af my project  (Read 17802 times)
christophbmw
« Reply #15 on: September 27, 2007, 07:23:12 PM »
Quote from: tjts1;34483
Lund
Is the M47 crank a direct drop in or do you have to make any modifications to make it fit in the M42?
Thanks
ive never done the swap myself, but i know some machining is required. Pretty simple from what i have read.
Febi Guibo
  • m42 reporter
« Reply #16 on: September 27, 2007, 09:33:37 PM »
http://www.m42club.com/forums/showthread.php?t=254
the crank requires some adjustments... about .5 to 1mm shaved off the end, and a woodruff cut into the end to hold the timing gear...
Support M42club.com !!
kramerica5000
« Reply #17 on: September 27, 2007, 09:40:48 PM »
That engine is so clean it looks brand new. Your attention to detail is impressive. Take lots of pics before it gets dirty! :)
jpod999
« Reply #18 on: September 27, 2007, 09:50:25 PM »
Gosh, that's beautiful.  Almost brings a tear to the eye.  ;)
What displacement is it?
Lund8200
« Reply #19 on: October 01, 2007, 02:57:48 PM »
Displacement is 2068 ccm.
Has made a deal with my buddy that the engine will be mounted 19-20 oct.
Will off course post my first experiense when turning the key....:eek:
Lund8200
« Reply #20 on: August 09, 2008, 06:56:40 PM »
Sorry for long waiting time...
But at last I´ve got the engine at a dyno, it made 177 horsepower and 210 Newton.
Have made approx. 5000 kilometers on it now and it still runs smoth.....
colin86325
  • -Receive: 15
« Reply #21 on: August 10, 2008, 01:08:48 AM »
Nice numbers--I'm sure you're enjoying the new power.  Which Shrick cams did you use?
Lund8200
« Reply #22 on: August 10, 2008, 11:35:34 AM »
I have used the 256 degrees cam from Schrick.
hesgone2fast
« Reply #23 on: August 11, 2008, 03:44:15 PM »
Hi Lund8200, great numbers!!
I have now finished my build up with basically your same setup except for M3 pistons (321hp, S52) And mine has 11,5:1 CR
What ECU are you using? injectors?
How is your idle with the schricks on your engine? I also have schricks, but I have not mounted them yet, for the run-in period I´ll use the stock ones.
One more thing, are those wheel or crank numbers?
« Last Edit: August 11, 2008, 03:46:39 PM by hesgone2fast »
Lund8200
« Reply #24 on: August 15, 2008, 02:48:11 AM »
Im using the stock ECU and injectors from a SAAB 900 turbo, approx. 200 cc/min.
The ECU needed some changes in the parameters, but it could run with standard settings.
The first/lowest curves shows before changes where made in the ECU.
My idle are sat a bit too high, around 1000 rpm, it could easily be dropped to 900 instead and still run smoth. (Next projekt)
These are crank numbers, you would properly get higher numbers with the higher compression ratio.
Good luck with you projekt!
quinn11m20
« Reply #25 on: August 17, 2008, 05:34:41 PM »
lund8200 that is a beautiful engine. I hope it serves you well.
DutchM42
« Reply #26 on: December 16, 2008, 02:45:49 PM »
Great project ! Just finished reading. It makes good power. :)
HaNasich
  • OO==00==OO
    • http://www.bangbros.com
« Reply #27 on: December 17, 2008, 09:28:40 AM »
Great post,
great numbers.
im going to go DASC on my car, do you have figures of the stock injectors vs. the Saab ones?
did it require any modifications in the fuel rail to fit the Saab injectors?
thanks
Ron.
WowMom
BTRA!
Lund8200
« Reply #28 on: July 19, 2009, 04:06:31 PM »
Hi guy, I am just back to tell you that the car is still going strong, now is has run approx. 15.000 km. with no problems at all!
Only thing that could be better is the idle, it´s a bit rough. Wondering if altering the timing of the camshaft would smooth out the idle?
Its feels like it sometimes misses a firing, has tried different plugs and new cables, last try is the coils.
wannam42
« Reply #29 on: May 27, 2010, 10:14:03 PM »
It's been a while. I've only seen this thread today and I'm inspired by it. Any updates on that idle projekt and the engine performance?
