Got a nutty problem that I need help with...
While working on a head gasket swap, along with all the other gaskets etc, I managed to drop the plastic cap from a tube of gasket sealant (the cap is the same size and shape as what you would find on a tube of toothpaste) directly into the lower timing chain cover. It is now down underneath the lower timing chain sprocket. I know, I know --- don't ask me how - it was an unfortunate miracle :eek: :mad:
To get it out, I need to either loosen or remove the lower timing chain cover. If all I need to do is make some ROOM, that would be better.
Do I have to remove the cover?
Can I just back out the bolts a little bit, so I can get something in there to grab the cap or chase the cap out?
Do you think I can do that without taking the crank pulley off?
Thanks for the help!
