Author Topic: a/c compressor  (Read 4564 times)
KenC
a/c compressor
« on: June 23, 2007, 07:36:33 PM »
I can't figure out how to put a new AC compressor belt on.  Does the compressor move at all?
a/c compressor
« Reply #1 on: June 23, 2007, 07:49:33 PM »
Yeah, there should be an adjuster on it. May be caked in grime and hard to spot, but it does rotate! On mine I have to loosen the two bolts that hold it, above the compressor, but I've seen different setups, so YMMV.
a/c compressor
« Reply #2 on: June 24, 2007, 02:02:54 PM »
There is no adjuster on the compressor itself. There is a third smaller idler wheel on the same belt just below the compressor. In the middle of the wheel there is a plastic cap. Remove the cap and underneath there is a large bolt. 17mm I think. Not sure. After you loosen the large bolt, reach underneath the idler wheel and undo the allen bolt. The idler wheel move up and down and allow you enough slack to replace the belt. It look me a couple of hours to figure it out a few days ago.
Good luck
Justin
a/c compressor
« Reply #3 on: June 24, 2007, 03:38:20 PM »
Quote from: tjts1;28424
Good luck
Justin
This is what I was referring to when I said there were different setups. I have no idler wheel on mine, just the mounting bracket for the compressor itself.
Edit:
Like this
« Last Edit: June 24, 2007, 03:43:24 PM by ak96ss »
The other one.
« Reply #4 on: June 24, 2007, 05:36:47 PM »
M42Iberia
a/c compressor
« Reply #5 on: June 25, 2007, 04:38:07 PM »
Quote from: ak96ss;28431
Edit:
Like this
Quote from: D. Clay;28438
are the compresors on both setup's the same??
a/c compressor
« Reply #6 on: June 25, 2007, 04:49:21 PM »
They should be, unless it was changed by another owner.
KenC
a/c compressor
« Reply #7 on: June 26, 2007, 09:46:59 PM »
So take off 11, loosen 9, and remove 10?  Then it should move?
a/c compressor
« Reply #8 on: June 26, 2007, 10:03:13 PM »
Quote from: KenCopperwheat;28599
Yes. That's how mine works.
M42Iberia
a/c compressor
« Reply #9 on: June 27, 2007, 02:05:41 PM »
Quote from: gearheadE30;28506
cool...looking to reinstall/replace mine with components  ever so kindly provided by ak96ss. :D  Probally need some insight!
KenC
a/c compressor
« Reply #10 on: July 01, 2007, 04:59:09 PM »
D. Clay,
Can you repost that picture of the other compressor?  It isn't showing for me.
Thanks,
Ken
KenC
a/c compressor
« Reply #11 on: July 01, 2007, 06:24:13 PM »
OK, nm.  Mine is the later style one, but I'm totally missing the idler wheel and the nuts/bolts associated with it.  So I guess I'm going to order those and give it a shot.  Too bad that idler wheel is like $50 :/
FL318is
Another question
« Reply #12 on: July 10, 2007, 11:40:44 AM »
How do you tell which of these 2 pieces of equip you have and are they the same thing and should I take a Mech 101 class?
http://www.realoem.com/bmw/showparts.do?model=AF93&mospid=47305&btnr=64_0807&hg=64&fg=50
http://www.realoem.com/bmw/showparts.do?model=AF93&mospid=47305&btnr=64_1026&hg=64&fg=50
Also, what is the difference between the 2 regarding function?
oldtimer
a/c compressor
« Reply #13 on: July 10, 2007, 10:11:09 PM »
Gary,
The first illustration shows a total breakdown of the compressor.  Now for the most part your average mech will not go through all the trouble to figure out which of the sub-component is not doing what it's suppose to do.  The second shown the complete compressor with everything install.  Somewhat "plug and play". Order Item #1 and you will get a functional compressor of course after doing all the neccessary maintenance.  Re-charging the system.
