Wide band Oxygen Sensor
Author Topic: Wide band Oxygen Sensor  (Read 2967 times)
Master
« on: June 17, 2007, 02:06:46 PM »
Hello guys, wanted to ask what is the ~price for a wide band oxygen sensor that will fit our cars,
some p/n or model number would be of help,
and what's the best/easiest way to log the A/F ratio from it.
I'm currently runnig with stock motronic.
Thanks for the imput :)
"Brake, heel and toe, brake, gas…" - The Drift formula.
Selling a unique e30 rear spoiler, good condition, see here
Master
« Reply #1 on: June 17, 2007, 03:24:27 PM »
OK, after intensive searching found one myself:
Bosch LSU4.2 bmwman91 uses it
Bosch P/N is 0258007057
Price on eBay US $64.90
Can someone comment on this thing are there alternatives?
How long did it last? Maybe bmwman91 can tell us :-) ?
Alpine003
« Reply #2 on: June 17, 2007, 11:37:11 PM »
Quote from: Master;27898
You would also need a wideband reader to interpret the 5v signal.
Here is a popular one that everyone uses with laptop/megasquirt or optional gauge
http://www.innovatemotorsports.com/products/lc1.php
« Reply #3 on: June 17, 2007, 11:53:14 PM »
Yeah, you cannot just use the sensor.  You need a controller for it...it is significantly more complex than the narrow band one we use stock.  The LC-1 is by far the best deal in existence right now.  I run it myself.
Master
« Reply #4 on: June 18, 2007, 02:26:16 AM »
Wow, thanks guys, knowledge really = horsepower :D
Tor Arne Kaasen
« Reply #5 on: June 18, 2007, 03:53:48 AM »
hei i bougt the http://www.innovatemotorsports.com/products/lm1.php
it workt perfect on the car i was tuning, havent used it on the m42 yet.
you can conect the controller to a ecu.
BMW E82 120d Coupe and BMW Z3 1,9 m44
« Reply #6 on: June 18, 2007, 10:24:58 AM »
True.  It has 2 analog outputs (both fully programmable).  One is set to emulate the stock narrow-band sensor when you receive it.  I think it is set to run a little rich personally, maybe for safety/liability on their side.  I used their free software to lean it out a little bit so it would run at 15:1 in closed loop instead of the 14:1 their settings had it running at.  That is ~7% less fuel in closed-loop mode!  Damn the LC1 is fun!
