WEll, now that school is almost over (YAY!!!) I'm trying to get geared up to do a timing system overhaul. Just as an idea of the condition, the engine has mostly highway miles but it has the original tensioner, guides, chain, gears, everything. And it has 200k miles.
My current plan is to take the intake out and clean it, remove the timing covers, cam cover, and t-stat cover as well as all of the parts needing removel to get to them. Then I will replace the guides, tensioner, and chain. I haven't taken a look at the gears yet, but I haven't been able to find new ones anyway. All new gaskets will go on as well as a new t-stat upon rebuild. I have heard many say that it is also good to check the oil pans, so I will be dropping the upper and lower pans to clean them and check for loose bolts and check the oil pump screen. New gaskets used there, too.
I'm not sure if I should remove the intake heater plate yet as I live in an area that gets down to about 5 degrees once in a blue moon. Any opinions? Pros/cons?
Depending on the amount of sludge, I may get the head cleaned, but I don't know if there is anything cost-effective to do while I am in there.
I know many of you have rebuilt engines, so any info regarding things to do while it is all apart or pitfalls I will run into would be great.
Hopefully I'll have some pics posted soon, I know everyone loves them
