solid lifters
Author Topic: solid lifters  (Read 9530 times)
kowalski
  • El\' Duder
solid lifters
« on: April 06, 2006, 07:46:55 PM »
where would i get solid lifters from for the m42?
Sale:
Fore Sale Thread
1991318is
solid lifters
« Reply #1 on: April 06, 2006, 10:26:11 PM »
Quote from: kowalski
no idea but those can fail easily and take a tole on the motor internals from experience.
kowalski
  • El\' Duder
solid lifters
« Reply #2 on: April 06, 2006, 11:00:22 PM »
Quote from: 1991318is
oh? that doesn't sound like much fun... i'v thrown a rod before and that kinda sucked... id hate to have that kind of issue with an 8,000 engine... what happend to you?
Sale:
Fore Sale Thread
solid lifters
« Reply #3 on: April 07, 2006, 12:20:01 AM »
Euro S50.  The parts are a direct swap.  Now as far as plugging the oil feeds, beats me.  I guess you will need to do some custom work there.
Pros:
Higher revving valvetrain (well, it is allowed to revv higher if the rest of the motor can)
Cons:
Can be noisy
Require shimming every 15k miles or so for peak performance
I guess once the crank damper shattering at 7200RPM thing has been cleared up we will know if converting is even worth the effort.  And if it can survuve, I guess someone has to be a guinea pig & see how high the internals can go before shattering.
kowalski
  • El\' Duder
solid lifters
« Reply #4 on: April 07, 2006, 12:27:03 AM »
so how would the solid lifters get oil if you plug the feeds? wouldn't you need an oil distribution point somwhere in there to provide lubrication? or how do they work? i'll be getting a custom dampener made so that wont be a problem. i just want some more information on the lifters, i dont want to drop somthing that i know nothing about in, and then bump the redline to 8,000+ and have a lifter explode.
« Last Edit: April 07, 2006, 02:59:33 AM by bmwman91 »
Sale:
Fore Sale Thread
solid lifters
« Reply #5 on: April 07, 2006, 12:30:50 AM »
dang I would love to hear a m42 at 8k.  7k sounds pretty mean w/ a cone filter
kowalski
  • El\' Duder
solid lifters
« Reply #6 on: April 07, 2006, 01:02:09 AM »
Quote from: asubimmer
i know how ya feel:) which is part of the reason i want it to go over 8! but i don't want to risk somthing like that happening...
Sale:
Fore Sale Thread
2002maniac
solid lifters
« Reply #7 on: April 07, 2006, 02:49:18 AM »
What would you do for a camshaft?  Solid lifter motors have much different cam profiles than engines with hydraulic lifters.
solid lifters
« Reply #8 on: April 07, 2006, 02:59:47 AM »
You would leave the oil outlets that get the cams/lifter tops.  You would have to plug the passages that feed the hydraulic lifters to keep them pumped.
kowalski
  • El\' Duder
solid lifters
« Reply #9 on: April 07, 2006, 02:14:26 PM »
Quote from: 2002maniac
i have a friend who grinds cams for a living, thats where i got the set im running right now. i also have 2 extra sets of cams in my room ready for regrinding, so it shouldn't be a problem.
Sale:
Fore Sale Thread
kowalski
  • El\' Duder
solid lifters
« Reply #10 on: April 07, 2006, 02:15:18 PM »
Quote from: bmwman91
ohh ok, that makes sense then. i thought you meant to clog all of the passages and that kinda made me worried:D
Sale:
Fore Sale Thread
Febi Guibo
  • m42 reporter
solid lifters
« Reply #11 on: April 07, 2006, 04:17:17 PM »
try beehive valve springs before fitting the solid lifters...
and let me know if they work!! :)
Support M42club.com !!
tim_s
solid lifters
« Reply #12 on: April 08, 2006, 07:58:22 AM »
this is what i've been thinking of trying. Which euro S50 ones are a direct fit bmwman?
2.1 200bhp, 175ft/lbs 318is
E46 330ci daily
solid lifters
« Reply #13 on: April 08, 2006, 12:40:25 PM »
Quote from: tim_s
Well, from what I remember, it was from the 1995 S50.  I am not sure what years they produced it from over there though (you lucky guys, got the REAL S50, the US just got a souped-up M50).
rwinter
crank pulley
« Reply #14 on: April 09, 2006, 01:55:22 AM »
Dave Rebello is building me a 8200 RPM engine with solid lifters. I was worried about the crank damper exploding so I designed my own crank pulley. It weighs about 2.4lbs- pretty light although its solid steel. I designed it to underdrive by approx. 20% which will free up some power and also keep the waterpump impeller from cavitating at high rpm. It should be on the dyno above 8000 in a week or so. What do you guys think?
