Author Topic: solid lifters  (Read 9541 times)
tim_s
solid lifters
« Reply #30 on: April 13, 2006, 04:10:19 PM »
haha i come from VW circles too! the reason for the different hyd and mech veedub camshafts was different valve lengths in relation to the cam IIRC so they were a completely different profile on the cams - it isn't an issue of lift and duration, they simply aren't interchangeable as the valves won't lift properly. that shouldn't be an issue on ours though as long as the lifters are the same dimensions.
 as for the euro S50B30 the reason for the aggressive cams on the euro model are it has ITBs so you don't have the idle pressure problems associated with a single throttle and wild cams. there really is no comparison between the US and euro motors, they are completely different, and the hyd. lifters aren't the issue.
solid lifters will allow for more lift from factory than hyds though
« Last Edit: April 13, 2006, 04:13:04 PM by tim_s »
2.1 200bhp, 175ft/lbs 318is
E46 330ci daily
2002maniac
solid lifters
« Reply #31 on: April 13, 2006, 04:39:10 PM »
Thanks for clearing that up Tim.
jbuttenshaw
solid lifters
« Reply #32 on: April 19, 2006, 03:20:14 AM »
Why do you need to block the oil feed? wouldn;t the oil just be blocked by the solid lifter thus be the same as with a hydro lifter?
rob_e30
solid lifters
« Reply #33 on: November 14, 2007, 01:41:24 PM »
Sorry to bring this back from the dead, but has someone here actually built a solid lifter M42 head?
