Sorry this photos are late. I said I will take some photos to show you just how clean the "white gas" can get the engine bay clean. Remember oil acts like a bounding solution when dirty like sand and dust clings to it. The white gas defuses pertrolium base substance hence when you spray white in that area it will dis-bond the dirt then all you have to do is spray it with air blow off any sand or dirt that use to be glued together by the oil.
By the way all this new way to catch the extra moisture from the crankcase, isn't that the same when you use the water seperator for your air compressor. If so once in awhile you'll need to drain the water that was collected. For a daily drive that's a lot of work without any major power gain, much like the COP mod a lot of machining and fabricating but no performance gain.
