Author Topic: The mess under the intake  (Read 330950 times)
kowalski
  • El\' Duder
« Reply #15 on: May 13, 2007, 01:50:32 PM »
interesting catch can. did you just plug the hose on the rubber elbow and make the crank vent go straight into the cup?
Sale:
Fore Sale Thread
romkasponka
« Reply #16 on: May 13, 2007, 01:54:19 PM »
Quote from: kowalski;25630
yes,
there is no oil in the SPRITE cup, just some water in cold season ;)
E30 318is M42
E36 318is M44
thebigbadyeti
« Reply #17 on: May 13, 2007, 02:49:54 PM »
While your cleaning everything up...clean up that motor as well :).... lol...
kowalski
  • El\' Duder
« Reply #18 on: May 13, 2007, 05:17:11 PM »
Quote from: romkasponka;25632
yes,
gotch ya. I'll probably do this... does it not act up at all? usually with a crankcase leak it gets unhappy...?
Sale:
Fore Sale Thread
oldtimer
« Reply #19 on: May 13, 2007, 08:36:55 PM »
Will do once I figure out how to attach photos to my reply.
FL318is
« Reply #20 on: May 13, 2007, 08:40:44 PM »
Quote from: oldtimer;25660
When you post a reply, scroll down below until you see Manage Attachments and there you have it.
romkasponka
« Reply #21 on: May 14, 2007, 01:57:00 AM »
Quote from: kowalski;25642
no any leaks, the engine is after complete rebuild..
E30 318is M42
E36 318is M44
« Reply #22 on: May 14, 2007, 02:49:17 AM »
Quick and dirty catch can (read fuel filter) until I find something more appropriate and I relocated the ICV (zip ties FTW!) because BMW's placement was stupid. More importantly, vacuum hoses are within easy reach without having to remove the whole intake.
romkasponka
« Reply #23 on: May 14, 2007, 04:00:42 AM »
where other end of filter is connected??
E30 318is M42
E36 318is M44
kowalski
  • El\' Duder
« Reply #24 on: May 14, 2007, 04:37:34 AM »
Quote from: romkasponka;25673
but doesn't that catch can with the hose in it basically act the same as a crank case leak, as its the valve cover vent.
Sale:
Fore Sale Thread
romkasponka
« Reply #25 on: May 14, 2007, 12:10:29 PM »
Quote from: kowalski;25680
yes, but I cant understand your mind :)
E30 318is M42
E36 318is M44
« Reply #26 on: May 14, 2007, 01:19:04 PM »
Quote from: romkasponka;25679
Under the rubber elbow between the air meter to the throttle body where the crankcase ventilation normally ends.
« Reply #27 on: May 14, 2007, 01:21:47 PM »
Most in line catch cans are sealed and not usually part of the PCV system. To work they would need to be similar to a water trap in a diesel fuel line. They must be periodically drained.
Where does air enter the crankcase on an M42? It exits from the valve cover to the throttle body?
« Reply #28 on: May 14, 2007, 02:50:28 PM »
Quote from: D. Clay;25703
Its a sealed system. As far as I can tell it doesn't take in fresh air anywhere. It just has an outlet for the blow by gases that get around the piston rings. If there was fresh air coming in, it would act like a vacuum lean and mess with the engine management. The blow by gases have already been burned in the combustion chamber and therefore contain no oxygen. Its a very toxic inert gas.
This is the catch can I use on my volvo. Its a high pressure air filter for pneumatic industrial machinery. Its very effective. Eventually I'll get another one for the BMW.
« Last Edit: May 14, 2007, 02:57:14 PM by tjts1 »
Alpine003
« Reply #29 on: May 14, 2007, 03:41:00 PM »
Quote from: romkasponka;25629
http://bp2.blogger.com/_MjQwpLOTuIM/Rkdbri1_SrI/AAAAAAAAAA0/SSQJGjBhcqk/s1600-h/IMG_0278.jpg
Lol, that's almost as bad as this:
No need to substitute all sorts of non car gizmos for this as Jegs or Summit carries catch cans for cheap.
Or if you wanna go for the bling: http://cgi.ebay.com/ebaymotors/Oil-Reservoir-Catch-Can-Tank-Mustang-GT-Probe-ZX2-SILVR_W0QQitemZ280113147994QQihZ018QQcategoryZ6778QQrdZ1QQcmdZViewItem
IMO, catch cans are really only needed if you do a lot of track events or drive fast on the highway for extended periods of time on a daily basis. Obviously if you have some sort of forced induction, then it's a must.
