Author Topic: 318is c101 wiring chart  (Read 11832 times)
320is_m42
« on: April 08, 2007, 12:28:52 PM »
i have a 91 318is wiring harness that i am trying to convert to a 83 e21 wiring harness,this harness has all relays and sensors intact. at the c101 plug the wiring is as follows.
pin 1    blue      alt charge warning
pin 2               empty
pin 3               empty
pin 4    br/vi     temp sensor
pin 5    bk/br     oil pressure
pin 6    gr/yl     unknown
pin 7    gn        ignition
pin 8    yl/wt    unknown
pin 9    bk        tach
pin 10             empty
pin 11  wt/bl    unknown
pin 12  br/bk     unknown
pin 13  vi/rd     fuel pump
pin 14  bk/yl     oil level sensor ?
pin 15  bk/gr     starter small connector
pin 16  wt/bk    unknown
pin 17             empty
pin 18   bk/yl    starter large connector
pin 19             empty
pin 20  yl/rd    abs brakes ???
can anyone help fill in the blanks on this harness or tell me if the ones that i have are right.
« Last Edit: April 08, 2007, 01:37:15 PM by 320is_m42 »
Febi Guibo
  • m42 reporter
« Reply #1 on: April 08, 2007, 12:59:50 PM »
well, we have this posted here:
http://ee1394.com/bmw/docs/e30_91.pdf
if that doesn't help, give a yell and we can research it more throughly...
edit:
I know that to reset the service light, you jump pins 7 and 19 (7 = inspection, 19 = ground)
see attachment for info from the 88-90 325i
« Last Edit: April 08, 2007, 01:38:59 PM by Febi Guibo »
Support M42club.com !!
320is_m42
« Reply #2 on: April 08, 2007, 01:41:23 PM »
after scanning the pdf file i found a couple more of the wires needed but the document doesnt show
pins 6 gr/yl
pin 7  green    ignition
pin  8  yl/wt  my mistake
pin 11 wt/bl
pin 12 br/bk
pin 16 wt/bk
 or i didnt find them
   any help
what is the SRS computer
« Last Edit: April 08, 2007, 03:00:50 PM by 320is_m42 »
Febi Guibo
  • m42 reporter
« Reply #3 on: April 08, 2007, 02:42:56 PM »
hmmm, well, from personal experience pin #7 is definitely the service indicator --i've reset my service lights a couple of times...
on page 24 of the 1991 electrical guide, the wt/bk runs from the SRS computer to the c101, so that would be pin #16.
on the same page, there's a br/bk line from the SRS computer to the warning module in our (pathetic) 2 light check panel, and considering that would be reset from the plug, that would be a good candidate for pin #12.
which leaves us with pin #6 and #11.... sigh!
« Last Edit: April 08, 2007, 02:46:49 PM by Febi Guibo »
Febi Guibo
  • m42 reporter
« Reply #4 on: April 22, 2007, 05:00:46 PM »
bumpeth
1991318is
« Reply #5 on: January 06, 2008, 03:46:55 PM »
Quote from: Febi Guibo;24240
bumpeth
Curious where you got that picture, I'm in need of one for a 94 325.
Thanks febi...
