Author Topic: What is the right operating temp?  (Read 3365 times)
Choking Hazard
« on: April 07, 2007, 05:16:16 PM »
My thermometer read 192 in the reservoir tank, but shows 7/8 to red on the temp guage.  What is the right temp to expect coolant to be at for correct system function?
:confused:
[SIGPIC][/SIGPIC]-Scott
Febi Guibo
  • m42 reporter
« Reply #1 on: April 07, 2007, 05:44:21 PM »
Stock thermostat is 190 F or thereabouts; I would try flushing yer system a few times!
Support M42club.com !!
Choking Hazard
« Reply #2 on: April 07, 2007, 08:31:54 PM »
Thanks.  I've flushed it (last weekend) plus all the usual stuff (t-stat, air bleed, fan clutch, and elec fan).  I'm thinking its the guage again, but so far, everything has been NOT IT, so....
ecpreston
« Reply #3 on: April 07, 2007, 09:30:55 PM »
Doesn't sound like you have an actual problem, other than your temp gauge being wrong. Stock tstat is 88C, or 190F.
« Last Edit: April 07, 2007, 09:35:25 PM by ecpreston »
Channing Preston
Madison Motorsports
Choking Hazard
« Reply #4 on: April 08, 2007, 12:14:00 AM »
Quote from: ecpreston;23176
Of course.
I looked on Pelican Parts and saw one 88 and one for 90 and i was thinkin F
Guess that is good, but I'll have to drop the cluster.  I can't look at a temp in the red and not freak.
Thanks for the clarification
individualist
« Reply #5 on: April 08, 2007, 06:39:19 AM »
Might be the temp sensor? It's the brownish yellow one that sends the signal to the temp gauge.
Choking Hazard
« Reply #6 on: April 16, 2007, 03:01:15 PM »
OK.
new t-stat $40
new fan clutch $60
new coolant $30
labor 3 hours (my time only has value to me, so $0.00)
candy thermometer $10
First $130 and 2 hours = 3/4 to 7/8 into red on temp gauge
Second $10 and 1 hour = unwavering midpoint reading on temp guage.
Lesson:  cluster failure more likely than cooling failure.  I've done this twice in a year and don't think there was a real problem either time.
If you are seeing high temp readings, first check the coolant temp!
« Last Edit: April 16, 2007, 03:08:16 PM by Choking Hazard »
badboypolar
« Reply #7 on: April 16, 2007, 03:24:17 PM »
The little brass nut on the back of the cluster are the ground nuts correct?
Choking Hazard
« Reply #8 on: April 17, 2007, 10:27:18 PM »
Yes, thems the suckers'
Double nut them if there is enough to thread a second nut on there.  Mine backed off after a year for the second time.
