turbo - questions !! - please help
Author Topic: turbo - questions !! - please help  (Read 4859 times)
vatos_p
« on: March 20, 2007, 12:59:15 AM »
yesterday i finished my car , i have mounted the manifold , turbo , downpipe
i have one question that no-one has answered yet...
i know that the oil return from turbo , must go someware but over the oil limit..
1. where did you put the oil return from the turbo
« Last Edit: March 21, 2007, 01:09:35 AM by vatos_p »
steer with the rear !!!
m44power
« Reply #1 on: March 20, 2007, 11:57:22 AM »
i think you have only to drill your oil pan someplace high
bar73k
« Reply #2 on: March 20, 2007, 04:14:05 PM »
I tapped mine into the block, was very easy to do and is definatly above the
oil level. Only thing is that i had the motor pulled apart when i did this.
the copper tube has been since changed to one long peice of hose because
it used to leak a little.
m44power
« Reply #3 on: March 20, 2007, 04:41:01 PM »
Quote from: bar73k;21831
your engine looks great post up some pics !
« Reply #4 on: March 20, 2007, 06:09:23 PM »
what EM are you planning on running?
vatos_p
« Reply #5 on: March 21, 2007, 12:56:01 AM »
PERFECT POWER SMT-7 is already connected and waiting...
i will use smt-7 fuel managment , boost control , and timing control , shift light for start... i thing i will be ok with that...
to the subject now , i have measured the oil pan , and the oil level is a litle bit higher than the oil pan... ( m42 with filter gets 4.8 liter oil ) ...
i had already seen the picture of your engine ( bar73k ) and i thought to go to the block but the spot you picked up is not straight , it is a litle bit curve , and the mechanik said that it will leak oil so i did not use your way...
then i thought the engine cap ( valve cover ) but there is no place to get the oil return...
thats why i am comfused... so if anyone else has an idea where to put the oil  return please make a suggestion...
sumyungguy
  • b.wood
    • http://www.shutterflick.com
« Reply #6 on: March 21, 2007, 02:32:37 AM »
As long as its drains down below the turbo and strait as possible you should be fine, I've never heard of it needing to be above the oil level, have a bung welded to the pan and use a quality a/n fitting. Having the feed line as close to the pump as possible helps with flow as well, but on the m42 thats not an easy task.
brad™
Gunni
« Reply #7 on: March 21, 2007, 03:39:33 AM »
Tap the block as close to the front of the engine and low as possible,
or wherever your turbo is mounted in bar73k´s picture you can see that you could route the line between the compressor and engine mount.
That would make it very straight
