Author Topic: Mustang Injectors in an M42 engine  (Read 261661 times)
stillmatick
« Reply #240 on: April 15, 2011, 09:45:27 PM »
is it worth the trouble going with mustang injector?
nomade30
« Reply #241 on: April 16, 2011, 02:51:29 AM »
Yes, changed the car completely.
BMW 6 Cylinder ARP head stud kits for $230 | M42/M44 ARP head stud kit for $195
Click here for more details
PRICES INCLUDE SHIPPING within the US!  PM me to order.
stillmatick
« Reply #242 on: April 16, 2011, 11:27:02 AM »
Quote from: autox320;102990
http://www.fiveomotorsport.com/fuel-injectors/?itemid=74
Note the new bosch number Fuel Injector: Bosch 0280156013
Yes they are RED now; these are the same as the yellows i bought few months ago and posted here.
About to swap them into our 318i DD.
so those will plug and play in the m42 engine without any modification???
bbarnumboy
« Reply #243 on: April 19, 2011, 02:28:32 PM »
so is this one  a good one to use?  so many part numbers all over this thread.   is this a 4 pintle and direct fit?
stillmatick
« Reply #244 on: April 19, 2011, 05:08:53 PM »
Quote from: bbarnumboy;103205
did some research last night and these are the correct injectors.
http://www.fuelinjector.citymaker.com/catalog/item/4494564/4532416.htm
sbarton
    • Duct Tape Motorsports - LeMons/Chump Endurance Racecar Rentals
« Reply #245 on: April 19, 2011, 05:11:18 PM »
I cannot for the life of me figure out what part number is really the one that works with no modification, no missing clips, no washers, etc.
Can someone just go here and link to the correct page with the fuel injector that will work with a stock or slightly modded M42.
http://www.fuelinjector.citymaker.com (cheapest rebuilt injectors around).
-Scott
bbarnumboy
« Reply #246 on: April 20, 2011, 12:39:25 PM »
what about the other ones linked above from fivemotorsport.com?  should the ones you just listed be a direct fit? and work perfect.
stillmatick
« Reply #247 on: April 20, 2011, 01:22:33 PM »
Quote from: bbarnumboy;103230
The fivemotorsport.com won't fit because is too long,the one i posted is a direct fit and is a 4-pintle.
dunny
« Reply #248 on: April 21, 2011, 09:55:03 AM »
Just ran my first 200 miles on the 318i.  Setup is a stock M42 with mustang 4 pintle injectors, COP kit, and stock airbox with AFE filter.  201 miles on 6.8 gallons is 29.55MPG....that was mixed driving, probably 75 miles of it on the highway.  I'm very pleased with that :)
stillmatick
« Reply #249 on: April 21, 2011, 02:25:17 PM »
Quote from: dunny;103245
i just bought these
can't wait to put them on with my chipped ecu and k&N filter. shit is already preppy as is and a gas guzzler,only get 300miles on full tank.
sbarton
« Reply #250 on: April 23, 2011, 05:30:01 PM »
What's the feeedback?  Have you installed them yet?  Do those injectors from Motorman fit and work correctly.  Any leaks?
-Scott
sbarton
« Reply #251 on: May 02, 2011, 10:36:27 AM »
Quote from: stillmatick;103246
i just bought these
Have you installed them yet?  Any issues.
-Scott
BBDirtbiking
« Reply #252 on: May 06, 2011, 12:17:22 AM »
Quote from: Balleristic31;103016
Left to right: a 155 injector that will work because of the slots for the clip, 155 that WILL NOT fit because it has no clip slot (this was where my problem occurred), stock injector, and a 150 injector with the slots (currently using these)
No one else has had this problem it seems, perhaps you failed to properly install that injector?
"The police call it reckless driving - I call it skill."
1991 BMW 318is
stillmatick
« Reply #253 on: May 06, 2011, 04:46:03 AM »
Quote from: BBDirtbiking;103586
the two skinny injector to the left will not work at all.
BOSCH 0280150556 4Port Injector
plug and play baby
BBDirtbiking
« Reply #254 on: May 06, 2011, 11:00:37 AM »
You are positive that those are plug and play? I want to cover my basis before spending $100 on new injectors that wouldn't fit. I have been reading on this thread that the Bosch 0280155700 was plug and play then recently, within the last month, that they wont fit the clips and handle the pressure.
So what you are saying is Bosch 0280150556 is the way to go, if so thanks for the heads up.
1991 BMW 318is
