Window Regulator?
Author Topic: Window Regulator?  (Read 6826 times)
FL318is
Window Regulator?
« on: March 19, 2007, 08:31:57 AM »
My pax window is intermittent when I push the button.  Sometimes it will work and go up all the way down.  At other times it travels max about 15mm.  Any thoughts?
« Last Edit: March 20, 2007, 08:23:01 AM by FL318is »
FL318is
Window Regulator?
« Reply #1 on: March 20, 2007, 08:22:46 AM »
Quote from: FL318is;21640
Am I the only one with a window problem?  I think it is a window reg but have not heard of them going out on E30s.  My E46 eats them.
jajou318
Window Regulator?
« Reply #2 on: March 20, 2007, 10:40:48 AM »
if you want to test it, take the door panel apart and run direct power from a battery to a drill to the motor of the regulator. if it goes up and down fine then it's probably your switch.
somewhat of a teaser...
FL318is
Window Regulator?
« Reply #3 on: March 21, 2007, 09:16:59 AM »
Quote from: jajou318;21798
Thanks.  I have an extra switch.
Alpine003
Window Regulator?
« Reply #4 on: March 21, 2007, 09:52:17 AM »
Damn you, you just jinxed me as my passenger switch literally went out yesterday. :D
All you have to do is lift off the shift boot and press out the switches from the bottom. Try switching the driver's and passenger switch to determine if it's a switch or not. Highly unlikely that they would both go out at the same time.
Window Regulator?
« Reply #5 on: March 21, 2007, 10:02:44 AM »
yup pushin them up is the easiest.  One of mine is tempermental about goin up and down, the other one has a blown bulb but still works fine :(
stuartgallafant
Window Regulator?
« Reply #6 on: March 21, 2007, 12:56:13 PM »
the switches seem to be a common problem over here! the regulators are solid. E46 regulators are poo!!
