ECU Plug
Author Topic: ECU Plug  (Read 4003 times)
ECU Plug
« on: February 28, 2007, 11:38:59 AM »
I was wondering if the m42 has the same ecu plug as say a m20?  I have a broken 87' 325is ecu and I want to wire the MS into the factory harness so a plug would be nice.  The 325 ecu is at home in gboro so I can't look at it but maybe one of you guys knows? :rolleyes:
ECU Plug
« Reply #1 on: March 01, 2007, 09:38:03 AM »
ttt
ECU Plug
« Reply #2 on: March 01, 2007, 10:56:50 AM »
i can send you my cooked m42 ecu for comparison, along with that antenna if you want.
no extra charge.
*edit
lol just read it twice over, you need a plug for comparison or would the actual ecu be good enough to compare?
ECU Plug
« Reply #3 on: March 01, 2007, 12:58:19 PM »
well I have a broken 325 ecu but I know a m42 one would work ;)
I can compare the 325 one to mine when I get home sat but if you don't want that broken ecu I'll take it. But you may want it if you go MS later I guess.
if nothing else a pic of the plug would be cool :)
Gunni
ECU Plug
« Reply #4 on: March 01, 2007, 01:11:01 PM »
they are not the same,
both a 3 row but the M42 is 88pin while the M20 is 55pin
ECU Plug
« Reply #5 on: March 01, 2007, 05:09:56 PM »
Quote from: asubimmer;20360
lol nope, MS won't be necessary for what im doing.
ill send it with antenna dude.
ECU Plug
« Reply #6 on: March 02, 2007, 07:29:36 AM »
awsome thanks again!
zerofreez
ECU Plug
« Reply #7 on: March 15, 2007, 02:08:51 PM »
Just a suggestion, but BMW sells break out boxes for diagnosis.  Have male and female plugs on the part.  Probably costs about 100 bucks to get one though.
