Gunni 318i/M42
Author Topic: Gunni 318i/M42  (Read 29525 times)
Gunni
Gunni 318i/M42
« on: March 29, 2006, 06:42:21 AM »
Hi guys,
nice to have a M42 only forum
I´m running a M42 powered 318i ´88,
I got the engine from a Red 318is that was hit in the back,
I swapped engine, trans, driveshaft and rear end in completely,
Car was hand painted before, but serves as a daily driver now, and
will always, I plan on painting it myself in a form of dark green (E30 original)
I´m runnnig a M20 flywheel, M20B20 clutch and pressure plate,
I had to mod the starter and use 1.5mm shims to put the starter a little more in front of the trans to not get the gear to stick, other then that it was all direct bolt on,
flywheel was lightened to 5.5kg or so, I used the pic Jordan made up in CAD.
I have raced 2 E30 325i´s at stoplights and was even all first 3gears.
I do have a SMT unit lying around, also a M30 afm , maybe putting the things together, who knows, maybe a MAP,
I do have a Zeitronix Wideband I have yet to install to check the AFR,
And this car doesn´t have a O2 bung in the exhaust from factory.
I´m putting it on some "16´s soon, not wide or anything, it´s just my "15 BBS one wheel got a flat tire and I dont´have any more "15 tires ;)
Anyway I guess thats enough from me,
Most of you know me from R3V, E30tech, BEN, or whatever.
I also need my username changed to Gunni :)
http://www.gstuning.net/files/files/m42stuff/m42brakes_on.txt
check the txt file for wideband AFR readings on a stock M42
« Last Edit: April 26, 2006, 02:26:07 PM by Gunni »
Froos
Gunni 318i/M42
« Reply #1 on: March 29, 2006, 08:06:11 AM »
Hi Gunni, welcome! You got any pics? Where are you located??
Febi Guibo
  • m42 reporter
Gunni 318i/M42
« Reply #2 on: March 29, 2006, 09:03:04 AM »
Holy cow... are you that dude from Iceland??
Support M42club.com !!
Gunni
Gunni 318i/M42
« Reply #3 on: March 29, 2006, 09:18:25 AM »
Indeed I am that dude from Iceland,
but why THAT dude??
what are you getting at,
I´ll post pics later on,
It´s got a Mtech I front now but poorly done by a PO so I´ll change it to facelift again
Febi Guibo
  • m42 reporter
Gunni 318i/M42
« Reply #4 on: March 29, 2006, 09:21:14 AM »
yeah man... sorry, I should have been more specific... yer 'gstuning' on E30 tech? either way, welcome!!
pls. check out our first 'ASK SO-AND-SO' thread... if you have any M42 questions for the man, they are totally welcome.
enjoy the board!
Gunni
Gunni 318i/M42
« Reply #5 on: March 29, 2006, 09:46:40 AM »
Thanks, I like individual based forums as it´s keeps more technical and less nonsense,.
I really don´t have any q´s for him, as I plan on running this as a daily
altought, I´d love to do this to it,
http://www.perfectpower.com/products/tic.asp
but until I have a secondary car, wich will be a 3.5 E30, I will keep hands of any standalone stuff :)
1991318is
Gunni 318i/M42
« Reply #6 on: March 30, 2006, 12:24:51 AM »
That's awesome, someone swapping in a m42, that's a rarity, finally someone smart
Gunni
Gunni 318i/M42
« Reply #7 on: March 30, 2006, 06:37:01 AM »
Above : When I got it
Gunni
Gunni 318i/M42
« Reply #8 on: March 30, 2006, 06:38:30 AM »
Gunni
Gunni 318i/M42
« Reply #9 on: March 30, 2006, 06:39:38 AM »
Here are the possible colors I want
Next up is a 3,91 LSD ,, a Viscous but hey, one can´t be choosie(?sp)
around these parts.
Gunni
Gunni 318i/M42
« Reply #10 on: March 30, 2006, 06:40:24 AM »
I´ll be putting in semi coilovers soon and hopefully KW shocks
e9nine
Gunni 318i/M42
« Reply #11 on: March 30, 2006, 07:20:00 AM »
Gunni
Gunni
Gunni 318i/M42
« Reply #12 on: March 30, 2006, 08:15:08 AM »
ahaa.....
I don´t get it
Gunni
Gunni 318i/M42
« Reply #13 on: April 06, 2006, 11:19:02 AM »
SMT6 install tonight,
ign control, fuel control,
Wideband as soon as I can,
Also MAP swap as soon as possible as well ;)
jens
Gunni 318i/M42
« Reply #14 on: April 06, 2006, 11:50:40 AM »
You have to take pic and som info Gunni :cool:
[SIGPIC]Delete [/SIGPIC]
