Hi guys,
nice to have a M42 only forum
I´m running a M42 powered 318i ´88,
I got the engine from a Red 318is that was hit in the back,
I swapped engine, trans, driveshaft and rear end in completely,
Car was hand painted before, but serves as a daily driver now, and
will always, I plan on painting it myself in a form of dark green (E30 original)
I´m runnnig a M20 flywheel, M20B20 clutch and pressure plate,
I had to mod the starter and use 1.5mm shims to put the starter a little more in front of the trans to not get the gear to stick, other then that it was all direct bolt on,
flywheel was lightened to 5.5kg or so, I used the pic Jordan made up in CAD.
I have raced 2 E30 325i´s at stoplights and was even all first 3gears.
I do have a SMT unit lying around, also a M30 afm , maybe putting the things together, who knows, maybe a MAP,
I do have a Zeitronix Wideband I have yet to install to check the AFR,
And this car doesn´t have a O2 bung in the exhaust from factory.
I´m putting it on some "16´s soon, not wide or anything, it´s just my "15 BBS one wheel got a flat tire and I dont´have any more "15 tires
Anyway I guess thats enough from me,
Most of you know me from R3V, E30tech, BEN, or whatever.
I also need my username changed to Gunni
http://www.gstuning.net/files/files/m42stuff/m42brakes_on.txtcheck the txt file for wideband AFR readings on a stock M42
