S50 trans
Author Topic: S50 trans  (Read 2455 times)
Gunni
S50 trans
« on: February 14, 2007, 07:00:48 AM »
Could I make that work?
I have one it´s from my S50B30 Euro,
I can get a clutch kit for it cheap,
and would thus want a lighter 240mm flywheel.
Actual savings is pretty good as a clutch kit for my now M20 setup is mroe then $400. and this clutch kit is not even close
This would be ideal when I turbo the M42 and
would use with a 3,25diff I have.
So does the M50/S50 transes bolt on?
2002maniac
S50 trans
« Reply #1 on: February 14, 2007, 07:57:52 AM »
I know it bolts up to the engine.  Not sure about the rear mount or driveshaft length though.
Vladi
    • http://www.bmwzone.ro/forum
S50 trans
« Reply #2 on: February 14, 2007, 08:01:33 AM »
Only way to know for sure is to try....if you ask me i don't think it will work, unfortunately.
Gunni
S50 trans
« Reply #3 on: February 14, 2007, 08:12:33 AM »
I don´t have concerns about the driveshaft as I have a number of them,
If the trans fits the engine, I should be able to bolt up a 240mm flywheel + a 240mm clutch kit,
Shouldn´t that be a safe assumtion,
