Boost
Author Topic: Boost  (Read 9105 times)
Boost
« Reply #15 on: February 28, 2007, 11:44:12 PM »
I think thats the only option for s/c unless you diy
franz
Boost
« Reply #16 on: March 01, 2007, 11:52:54 PM »
Quote from: Shocker;20199
Yeah that’s my car but now it doesn’t look anything like that I did a MAF conversion, the air filter is behind the bumper so its alot cleaner.  The motor is all stock, the supercharger runs off the P/S belt and the manifold is the bottom portion with a plate welded on it.  Also Roots style and twin screw aren’t they the same they both have two rotors that one spins clock wise and the other counter clock wise????
that picture is that a MASC kit
Shocker
Boost
« Reply #17 on: March 02, 2007, 12:13:16 AM »
Quote from: franz;20407
Actually it’s a KO performance Kit Made by Joe the scam artist which started up MA.  Never buy from that dumb ass.  He tells you it’ll work just to make a sale
Alpine003
Boost
« Reply #18 on: March 02, 2007, 11:01:11 AM »
Quote from: asubimmer;20343
MB SLK Kompressor ;)  Very well matched for M42.
franz
Boost
« Reply #19 on: March 03, 2007, 09:24:02 AM »
Quote from: Shocker;20409
i talked to dose guys and all i hear it bad comments
but at one point i was` ready to buy there kit lucky i didnt
and what you think about the m62 s/c i been meaning to replace the blown s/c with m62
« Last Edit: March 03, 2007, 09:26:32 AM by franz »
black318i
Boost
« Reply #20 on: March 04, 2007, 12:54:03 PM »
Quote from: ScreamerBeemer;20264
I gonna ask a similar question that Shocker did. Any rough ideas how much boost can be safely pushed on a bone stock M42? I mean stock compression ratio, internals, and on the motronic. I'm guessing 5....6 lbs?
Quote from: 2002maniac;20291
with poor tuning 5-6psi will be pushing it.  With a proper tune, 1bar shouldnt be a problem IMO
The DASC runs 7psi and only an FMU for fuel and nothing for timing.
I run 10.5 PSI with a piggy back.  I'd be willing to run more if I coud find a better Unichip tuner and install a thicker HG.
