Bad Diff Bushing
Author Topic: Bad Diff Bushing  (Read 5112 times)
Bad Diff Bushing
« on: March 27, 2006, 07:13:48 PM »
Could this be the culprit of my clunk? Seems like it's time to get an M coupe bushing.
Choking Hazard
Bad Diff Bushing
« Reply #1 on: March 27, 2006, 10:18:33 PM »
didn't I just answerr this on Bimmerforums as SGB?  It was the first time I had been there since this board opened.
[SIGPIC][/SIGPIC]-Scott
1991318is
Bad Diff Bushing
« Reply #2 on: March 27, 2006, 10:38:53 PM »
Ya, I'd think that could have a hand in the problem.
kowalski
  • El\' Duder
Bad Diff Bushing
« Reply #3 on: March 28, 2006, 12:07:51 AM »
haha that looks 100x worse then my bushing... i'm gona do mine one of these days....
Sale:
Fore Sale Thread
1991318is
Bad Diff Bushing
« Reply #4 on: March 28, 2006, 12:09:26 AM »
Quote from: kowalski
I ahven't been under my car many times since I bought it(the parts are layin in my room) so I'm hoping mine isn't that bad and is still good.
Bad Diff Bushing
« Reply #5 on: March 28, 2006, 12:13:14 AM »
In that case I need to get the bushing stat!
What's the easiest way to tackle replacement?
kowalski
  • El\' Duder
Bad Diff Bushing
« Reply #6 on: March 28, 2006, 12:33:09 PM »
you gotta remove the diff cover and press it out. last time i had to do this (cab's) i used a punch, it took about 10 min aside but it beats 40 min drive to vancouver to use the press at the machine shop.
Sale:
Fore Sale Thread
Bad Diff Bushing
« Reply #7 on: March 28, 2006, 12:36:00 PM »
man that looks rough.  I don't have clunks but that makes me not want to look under my car so I don't start buying tons of bushings, although it wouldn't hurt.  I really want to change my rear subframe bushings.
What else?
« Reply #8 on: March 28, 2006, 10:08:13 PM »
The differential is bolted to the rear crossmember. If the rear of the differential moves radially opposite the torque of acceleration, it seems that there would also be a degree of flex in the crossmember bushings. I am waiting on the parts to drop the crossmember and replace all of the bushings and brake lines at the same time. My 318is has 198,000 miles on it.
Bad Diff Bushing
« Reply #9 on: March 29, 2006, 07:08:54 PM »
Bimmerworld carries a urethane version for 8 bux more than the stock bushing, think I'll go with this one.
http://www.nexternal.com/bimmerworl/Product710
edit: the street bushing in the link above is like group N rubber, good/bad?
« Last Edit: March 29, 2006, 07:20:35 PM by Eurospec »
