Rebuild: Tolerance questions
Author Topic: Rebuild: Tolerance questions  (Read 3815 times)
badboypolar
« on: February 01, 2007, 01:02:50 PM »
So I've looked in two bentleys and found nothing as to what the tolerances of some parts.
1) piston space from wall
2) all crank tolerances (rods, main bearings, play)
Thanks guys.
Febi Guibo
  • m42 reporter
« Reply #1 on: February 02, 2007, 06:55:53 AM »
we got it here:
http://m42club.com/forums/showthread.php?t=964
the interface is a little confusing, let me know if you have questions...
Support M42club.com !!
badboypolar
« Reply #2 on: February 02, 2007, 09:41:00 AM »
Yeah I looked there and couldn't find it and I swear I hit every page available.
2002maniac
« Reply #3 on: February 02, 2007, 10:59:01 AM »
Do you have the E36 bently?  I know it's in there.
badboypolar
« Reply #4 on: February 02, 2007, 11:10:47 AM »
I have the PDF version one. Where are the specs, cause I've look through all 800 pages and I must be blind.
Thanks for the help guys.
cecotto
    • http://www.cecotto.dk
« Reply #5 on: February 02, 2007, 11:14:12 AM »
Here you have the specifications directly from the BMW TIS (Technical Information System)
Sorry, i only have this available in German, but if you spend just a few minutes with it i'm sur you will be able to identify what you need.
But here you have some translations:
General:
 * Stufe 1 = First oversize
 * Gelb = Yellow
 * Grün = Green
 * Weiss = White
 * Kurbelwelle = Crankshaft
 * Lager = Bearing
 * Spiel = Play
    (Kurbelwellenlagerspiel = Crankshaft bearing play)
Img 2:
 * Kurbelwellenführungslager = Crankshaft guidebearing
 * Pleul = Connecting rod
Img 3:
 * Kolben= Piston
I hope this helps you!
« Last Edit: February 02, 2007, 11:28:02 AM by cecotto »
Steffen Otto Jensen
E30 318is
E30 M3
badboypolar
« Reply #6 on: February 02, 2007, 12:18:22 PM »
That is awesome. Thanks!
Funny cause I looked in the TIS and could not find this.
« Last Edit: February 02, 2007, 12:25:20 PM by badboypolar »
