Author Topic: Fuel Pressure Regulator Leak - 91' 318i  (Read 2897 times)
othatseric
« on: April 26, 2017, 10:50:00 AM »
So i recently refreshed some of the fuel system, I replaced the stock injectors with some mustang ones and the o-rings on the FPR with some generic ones and the short fuel lines going to the rail. I hadto bend the flange a little bit on the fuel rail to pry off the FPR.
When I got the car idling, it had a pretty bad misfire and fuel was leaking from the FPR. I was wondering if anyone knew if it had to be in a specific orientation? Or does the o-rings on the FPR specific to it? The generic o-rings are a little thinner than the original ones. And the FPR I knew was working originally.
Thanks for any help!
"Overkill is underrated my friend"
-Col. Hannibal Smith
Re: Fuel Pressure Regulator Leak - 91' 318i
« Reply #1 on: April 26, 2017, 03:10:44 PM »
I'd take some time to R&R those FPR o-rings. This is one of those cases that I'd use the pricey OEM updated ones, or a quality alternative. They're made from a far superior material, usually in a pretty lime green color. The older black rubber material isn't quite as resistant to oxygenated fuels.
othatseric
« Reply #2 on: April 26, 2017, 04:17:38 PM »
Okay Ill splurge this time :p Do you happen to know the p/n for the rings I need? Or if they're even sold separately? I checked out a brand new FPR from rockauto that includes the o-rings, and its about 70$ cad and the most expensive one is at 150$ cad.
« Reply #3 on: April 27, 2017, 04:43:49 PM »
According to RealOEM, part numbers are for a 5X1,5mm (13531720252) and a 20X2,5mm (13531720251).
