Author Topic: E36 M42 DME 1.7.2 error  (Read 4865 times)
selespeed
« on: August 24, 2016, 01:26:36 AM »
i have been having this lately or maybe for a few months already...
DME 1.7.2 errors when diagnosed:
100 Engine Control System
Does anyone know what this error is? How can I rectify this?
In addition, the service indicator light stopped at "orange" warning level. But did not advance to RED even after 6 months of driving. But i changed my oil at regular intervals by monitoring the mileage
Thanks
teo
Ivan_S42
  • Freshly Registered!
Re: E36 M42 DME 1.7.2 error
« Reply #1 on: August 25, 2016, 05:40:18 PM »
I assume on some of the sensors (cams, crank or oxygen)
I saw somewhere a table of sensors resistance so you could do a checkup on your own to see if sensors are not broken.
Hope it helps
selespeed
« Reply #2 on: August 25, 2016, 11:34:31 PM »
Hope it helps
the sensors are new! i don't think they're broken. because if they're, DME would have recorded these errors. Btw, error code 100 is about DME. Where is the relay for DME located?
colin86325
  • -Receive: 15
« Reply #3 on: August 26, 2016, 10:40:11 AM »
Yeah, that seems like an ECU-related  code.
The relay will be under the plastic cover that runs across the top of the firewall.
selespeed
« Reply #4 on: August 26, 2016, 02:30:41 PM »
thanks. i checked there are 3 relays of BMW M colors. which is the one? i wonder if i can get a manual on this. wiring diagram
1998ccc
  • -Receive: 6
« Reply #5 on: August 26, 2016, 11:21:48 PM »
Normally white.  It's the one with 5 pins  The other 2 have 4 and are fuel pump and o2 heater.
selespeed
« Reply #6 on: September 09, 2016, 10:40:26 AM »
i have the relay replaced and the error still appears even after resetting it. therefore, the problem is not solved and is due to something else. i am wondering if persistent problem in a/c is the cause of the problem. the error code 85 is due to a/c compressor that is forced on all the time (e36 DME in a e30 chassis). so this error 85 is always on. maybe the mechanic did something to make it on all the time in order to  overcome a/c problem.
how do you guys solve the a/c compressor problem with a e36m42 engine in e30?
cristimm
« Reply #7 on: September 11, 2016, 07:22:10 AM »
Thanks
teo
Do you have a custom chip installed?
selespeed
« Reply #8 on: September 11, 2016, 10:24:20 PM »
Thanks
teo
No. everything is stock. original DME
