Exhaust question
Author Topic: Exhaust question  (Read 4416 times)
Froos
Exhaust question
« on: July 17, 2016, 04:15:24 AM »
Guys i need help and i would really appriciate a reaction
Im having problems ordering the exhaust with the cat, so the part after the header. According to some ebay
Sellers the 318i is the same as the is cat...(on an e30), is that true??
Like this guy:
http://m.ebay.com/itm/1991-BMW-318i-318is-1-8L-CARB-Magnaflow-Direct-Fit-Catalytic-Converter-Exhaust-/151873898895?nav=SEARCH
« Last Edit: July 17, 2016, 04:16:58 AM by Froos »
Darky
  • -Receive: 23
Re: Exhaust question
« Reply #1 on: July 18, 2016, 03:05:38 AM »
In America probably, they never got the m40 engine.
So every 318i was a 318is minus suspension.
Hope this helps
Rohan
318_IS
« Reply #2 on: August 11, 2016, 03:15:07 PM »
I'm gonna ask my question here because it is more or less about the same.
Is the part after the header available without catalytic converter?
Just the piping with the flanges and thread for the o² sensor.
There aren't emission regulations over here and my catalytic converter was hollowed
out by the previous owner which makes a terrible noise now. Or
are there other options to smoothen the noise? ;D
Froos
« Reply #3 on: August 11, 2016, 04:57:35 PM »
Ill buy that old pipe if you find that pipe without cat...., you should have a resonance box fitted in between the cat and end muffler, its like an extra muffler. Maybe the previous owner also fitted a new end muffler and from what i read sound horrible
318_IS
« Reply #4 on: August 12, 2016, 02:10:22 AM »
The third part of the exhaust is still ok. It has the resonance muffler and end muffler which is stock like in the second picture.
But it's the pipe between the header and resonance muffler which is not ok  :(
The cat converter has been cut open and welded again. So i think the ceramic meterial has been removed
to create better flow...But it makes such a terrible clattering, resonating sound when i rev.
cristimm
« Reply #5 on: August 12, 2016, 02:38:59 AM »
What brand is the new exhaust system from the last pictures?
Froos
« Reply #6 on: August 12, 2016, 05:08:44 AM »
I would cut open again that cat and see if there are any loose metals flapping about when you rev it, could cause that sound. Again i dont know where you are lokated but ill happyly take any spare exhaust parts you might want to get ride of. Im currently cutting and welding a 318ti e36 exhaust and its a pita!
Froos
« Reply #7 on: August 14, 2016, 11:58:12 AM »
Froos
« Reply #8 on: August 14, 2016, 12:32:41 PM »
Looks like the pipe you need
318_IS
« Reply #9 on: August 16, 2016, 12:49:31 AM »
i don't know, its a picture from google images.
It came from here http://www.bimmerforums.com/forum/showthread.php?1056710-header-wrapping
318_IS
« Reply #10 on: August 16, 2016, 09:54:33 AM »
I'm living in Belgium. I can cut open the cat again but i'm not a good welder  :-\ The pipe on the ebay-advert also isn't plug and play  :(
Any other suggestions?  :D
Froos
« Reply #11 on: August 16, 2016, 03:39:05 PM »
Wow what are the odds, im dutch but livin in belgium as well! Livin just north of antwerp
« Last Edit: August 16, 2016, 03:41:24 PM by Froos »
