Ignition refrence
Author Topic: Ignition refrence  (Read 2818 times)
Gunni
Ignition refrence
« on: January 22, 2007, 03:50:47 AM »
I´ve never belived my 115deg to be accurate especially when I´ve needed to dial in more advance , it was in the high 30´s at WOT and high 40´s in low load,
But I was reading and my xms reads the ignition refrence from the cam shaft sensor and not the timing wheel, so I guess I need to put the sensor and mark on the same spot and then calculate the numbers of the timing wheel,
So I guess I need to double check everything,
And can you guys verify that the Arrow mark on the chain cover and a little mark in the timing wheel line up at TDC??
bar73k
Ignition refrence
« Reply #1 on: January 22, 2007, 05:19:15 AM »
Quote from: Gunni;17988
Yes the arrow mark on the chain cover and mark on the timing wheel line up
at TDC..... im 95% sure.
Gunni
Ignition refrence
« Reply #2 on: January 22, 2007, 05:51:44 AM »
What are your settings?
bar73k
Ignition refrence
« Reply #3 on: January 22, 2007, 11:36:25 PM »
Quote from: Gunni;17997
what do you mean by that?
Gunni
Ignition refrence
« Reply #4 on: January 23, 2007, 03:09:54 AM »
what are the ignition settings in your engine management,
just post them all and while your at it, why don´t you post all the info into here
http://www.m42club.com/forums/showthread.php?t=1678
bar73k
Ignition refrence
« Reply #5 on: January 23, 2007, 05:01:28 AM »
i left my laptop at work today, ill have a look tomorrow an see what i can get off it.
