asubimmer's turbo thread! [/thread]
Author Topic: asubimmer's turbo thread! [/thread]  (Read 19680 times)
« Reply #45 on: November 21, 2006, 02:20:21 AM »
Quote from: JiXer;14206
Whats the status?
well the manifold is still up in the air, but I have all the other parts.  Just waiting to install once I get the manifold situation finished :D
vjlax18
« Reply #46 on: November 27, 2006, 08:44:24 AM »
Did you ever figure out the manifold?  The factory maifold may work, but the flange will have to be drilled out, etc.  In my case, I'm looking at making a maifold that sits the turbo about 2" further forward then needed.  Eventually I'll be moving the engine back the same 2" and the shock stock is in the way.
« Reply #47 on: November 27, 2006, 09:25:30 AM »
I got the COP conversion done yesterday and I should be getting a manifold for a turbo m50 soon.  I think thats going to be the best bet since they are tubular and it will be easy to modify it to fit our engine.  I'm waiting on MS but I should be running it in the near future :)
e9nine
« Reply #48 on: November 27, 2006, 06:29:05 PM »
Jon Volk @ 666fab just made an m42 mani. I'd contact him for pricing info .... he posted on r3v...
« Reply #49 on: November 27, 2006, 06:39:55 PM »
I'm pretty sure its 800+ so forget that lol ;)
nobrakese36
« Reply #50 on: November 27, 2006, 07:04:14 PM »
Hey m50 and m42 manifolds have the same spacing/bolt pattern, so you could just remove two of the ports(tubes) and weld it closed,this should be a good solution to your manifold problem.
« Reply #51 on: November 27, 2006, 07:15:37 PM »
Quote from: nobrakese36;14527
exactly ;)
nobrakese36
2002maniac
« Reply #53 on: November 28, 2006, 11:09:28 PM »
Quote from: nobrakese36;14590
Im thinking about foing turbo this any good
http://cgi.ebay.com/ebaymotors/T3T4-Internal-V-Band-Turbo-T3-T4-8-3-PSI-60-Trim-60-A-R_W0QQcmdZViewItemQQcategoryZ33742QQihZ001QQitemZ110058956284QQrdZ1
a gt28rs will make good power with less lag.  GT series turbos > T3
you can find them on ebay pretty cheap too.
Didnt you have like 12.5:1 CR? Getting different pistons?
vatos_p
« Reply #54 on: November 29, 2006, 01:21:15 AM »
I personaly think that T3 is al litle bit small for m42 318is , because all the past year i am doing a reaserch because i am going to put a turbo into my 318is... i am going to use a Garrett GT 28/60 , v-mount intercooler , and everything else handmade by me and my friend... ( we are crazy people - we do turbos in our cars - till now we have made 3 cars you will not believe )... for fuel managment i am going to use a " splitsecond additional injector controler for 4 injectors ( it is programmable via laptop , you make a map while you drive  ) with handmade intake ,and 4 extra injectors ( it is better than change the factory injectors with bigger and put a chip into the cpu because you can't make changes anytime you want and you can program it yourselve ) , i will put an oil cooler frontmount... hopefully i will begin my project these days , i will take photos of everything and let you know about everything....
steer with the rear !!!
Gunni
« Reply #55 on: November 29, 2006, 07:29:44 AM »
vatos, can the split second kit control ignition??
If not check out the SMT6 unit, it can and will work great on a M42, also you can have the extra injectors work depending on boost, and retard ignition depending on boost as well
nobrakese36
« Reply #56 on: November 29, 2006, 10:29:14 AM »
Yes, if i lower my compression with a MLS HG it should be around 10.2,though.
« Reply #57 on: November 29, 2006, 11:41:38 AM »
vatos p, the 50 trim t3 looks pretty perfect on the m42 when I mapped it on the compressor map.  It should have full boost about 3k if not 2.5k.  Although a t3 would be good for fast spool, if you want huge #'s you prob would want a bigger turbo but the tradeoff is lag...
The turbo just depends on what you plan to do w/ your car and your goals.
vatos_p
« Reply #58 on: November 30, 2006, 02:50:25 AM »
no splitsecond can control only extra injectors
vatos_p
« Reply #59 on: November 30, 2006, 05:39:56 AM »
I Am Thinking Of Using The Smt7 , It Has All The Goodies Of Smt6 But Also A Boost Controler...
Do You Think It Will Work ?
Please Tell Me If Anyone Has It And Have Worked It To Know More Details...
And Thank You For The Tip....
