asubimmer's turbo thread! [/thread]
Author Topic: asubimmer's turbo thread! [/thread]  (Read 19717 times)
Gunni
« Reply #60 on: November 30, 2006, 06:24:09 AM »
I haven´t used a SMT7 for boost, but the settings are real easy,
the SMT7 should meet all your needs and then some,
I´m almost finished with my m42 swap, when it´s done, I´m going to alpha-n the engine using a SMT6, will report back when I get going, was going to use a MAP sensor but decided it didn´t matter as neither measures air really,
a O2 will be there for closed loop after the re-tuning
vatos_p
info
« Reply #61 on: December 01, 2006, 04:04:25 AM »
i have the 184s1 m42 318is engine...
the man i bought it from told me that he has e36 m42 engine installed , full with ecu , gearbox and rear axle...
i do not know if he is telling me the truth , because the engine does not have the intake of a 1996 m42 , but the intake of an 1992 engine... it has O2 sensor ,  but other than that , i do no know... could someone tell me where the ecu is located , because it has more than one ecu... it has abs unit on it , and there are 2 ecu in the car.. one is located under the steering wheel , and one is in the passenger closet... whitch is the engine ecu ? and how am i going to find what model is the ecu ?
steer with the rear !!!
Gunni
« Reply #62 on: December 01, 2006, 05:19:21 AM »
the ecu is above the glove compartment, read the the numbers beginning with 280 ......
I think it should be 174 for a M42 from a E30
« Reply #63 on: February 04, 2007, 01:38:23 AM »
well I have been hush about this for a bit now. Its been slow w/ college and work. I have the manifold as you guys know. I also picked up a dual BB and ceramic bladed gt28r ;) I am getting the MS1 v3.0 and a wideband o2 soon. I am thinkin about NGK's new wideband. I need to get the MS asap b/c I would like to get it up and running before I get the turbo on to make tuning easier.
« Last Edit: February 05, 2007, 01:10:41 AM by asubimmer »
« Reply #64 on: February 04, 2007, 03:03:57 PM »
well w/ all the new stuff I decided to start a new thread since a lot of the stuff in this thread isn't conserning the new plan.
please see http://www.m42club.com/forums/showthread.php?t=2005 for the new thread!
« Last Edit: February 04, 2007, 03:22:01 PM by asubimmer »
