more
there is constant fault codes on AC. this ecu always says AC is on even though AC compressor is deliberately turned off. i do not know what the mechanic has done. because the e36 AC has two parts and e30 is just a simple AC signal that informs the DME whether it is on or off.
how do you guys solve this problem such that when AC compressor is turned off, it will tell the DME properly in order to get rid of this error 085
thanks
teo
