To solve e46 venting issue, I just used e46 inner tie rods with e36 outers. My rack is in the rear holes in the subframe and for the linkage I used a corsa linkage, which was also crazy close to headers, so I put 6mm of spacers under the engine mounts (akg 75d mounts) now it clears perfect (mine is 325i however). For hoses I used the e30 high pressure line to the pump and just bent it to fit, the other hose I used the e46 one which works perfectly. I also used the e46 cooler which I just mounted under the radiator.
Best mod yet, steering is amazing
