Author Topic: wheel bearings  (Read 3115 times)
RED IS 91
wheel bearings
« on: January 12, 2007, 04:21:40 PM »
I can hear some grinding at the front passenger side so I suspect I've got a wheel bearing that's going to need replacing soon. I checked the brakes and they are fine .
My car has 187,000 miles on it and was wondering what others got on theirs before the bearings started to fail ? I certainly can't complain with that mileage .
I've seen two different write ups on the replacement and haven't decided which to take yet . The puller method or the slam the wheel in your face method .
Opinions welcomed :)
sepehr
wheel bearings
« Reply #1 on: January 12, 2007, 05:11:35 PM »
I have to replace my rear bearings.
http://cgi.ebay.com/ebaymotors/FWD-FRONT-WHEEL-TOOLS-BEARING-REMOVER-INSTALLER-TOOL_W0QQcmdZViewItemQQcategoryZ35625QQihZ007QQitemZ170069453344QQtcZphoto#ebayphotohosting
I saw this thing on ebay, anyone wondering if would work?
Just so I'm not completely jacking this thread, the guy has puller sets with slide hammers too, if you don't want to slam the wheel in your face.
thumper3ld
  • fathead ***
wheel bearings
« Reply #2 on: January 13, 2007, 12:51:02 AM »
If it's the front bearings, just buy them from bavauto. They sell wheel bearing replacement kit which is basically the whole hub and the dust cover for $89. No need to press them out or anything.
kowalski
  • El\' Duder
wheel bearings
« Reply #3 on: January 13, 2007, 04:04:36 AM »
i believe you can only buy the front bearings as a hub assembly.
Sale:
Fore Sale Thread
RED IS 91
wheel bearings
« Reply #4 on: January 13, 2007, 05:56:51 AM »
Quote from: kowalski;17515
that is correct
wheel bearings
« Reply #5 on: January 13, 2007, 09:33:04 AM »
You do need a 36 mm socket for the big nut. The rear is a 30 mm.
thumper3ld
  • fathead ***
wheel bearings
« Reply #6 on: January 13, 2007, 07:37:08 PM »
Hence why i said, "if it's the front bearings"
