ebay.de ecu chips
Author Topic: ebay.de ecu chips  (Read 3572 times)
kowalski
  • El\' Duder
ebay.de ecu chips
« on: January 09, 2007, 05:36:11 PM »
http://cgi.ebay.de/Tuningchip-318is-E30_W0QQitemZ120072292629QQihZ002QQcategoryZ73673QQrdZ1QQcmdZViewItem
discuss.
10kw~14hp
24nm~17.7 lb/ft tq
and the real kicker is the 7,400 rpm rev limit...
rough translation of description:
Tuningchip BMW E30 318is Tuningchip for the following BMW model: E30/318is The chip is for controllers with the number: 0261 200,175 The vehicle is with high engine speed and hangs substantially better on the gas. The increased output which can be expected is with genuine 10Kw. The torque increase is approx. with 25 Nm. Exhaust system, sharp cam shafts, treatment of heads must was inserted because the performance curve shifts upward and the speed limit is higher with each Tuningumbau straight if sport air cleaners. The speed limit is with this Tuningchip with 7400 rpm. only with 318is L I E F E R U M F A N G: CHIP and fitting instruction Advantages: Achievement and torque increase over the entire speed range without speed limit. No effect on the exhaust investigation!! Simple installation. is (plate bases) fitting instruction participates only put.
Sale:
Fore Sale Thread
AL GReeNeRy
ebay.de ecu chips
« Reply #1 on: January 10, 2007, 01:23:59 AM »
"7400 rpm. only with 318is"
i like that part.. but werent the euro 318is more powerful than us? either way, 261 is our ecu number..
1991 318is : brilliantrot
Gunni
ebay.de ecu chips
« Reply #2 on: January 10, 2007, 03:20:10 AM »
7400rpm??
Is this for real, I´ll need to retune the whole standalone now :eek:
Wich I´ll gladly do if this is something the engine can handle,
kowalski
  • El\' Duder
ebay.de ecu chips
« Reply #3 on: January 10, 2007, 04:25:30 AM »
Quote from: Gunni;17288
7400rpm??
i found another one on there, a retuned ecu, for 200 euro. new rev limit of 7,500
Sale:
Fore Sale Thread
kowalski
  • El\' Duder
ebay.de ecu chips
« Reply #4 on: January 10, 2007, 04:26:04 AM »
oops double postage.
Sale:
Fore Sale Thread
e9nine
ebay.de ecu chips
« Reply #5 on: January 10, 2007, 10:46:09 AM »
Raised rev limits have two sides to them. The obvious plus of you being able to hold gears longer as needed in certain areas on the track/auto-x course. The disappointing fact of it being useless as the stock or very mildly modded motor isn't necessarily able to use it to full advantage per se.
For those of you with worked motors running piggy backs -- >:cool:
 For the rest of us -- > :rolleyes:
When shifting @ 7200 with my motor I feel it's at it's limit @ WOT and with an extra 200 or so revs I won't be comfortable doing it repeatedly unless the chip shifts the entire curve better than what I have now to make it worthy (and I don't like people who sell stuff without dynos of before and after in general)
My dyno with a Mark D chip (@ the wheels)
« Last Edit: January 10, 2007, 12:09:17 PM by e9nine »
Alpine003
ebay.de ecu chips
« Reply #6 on: January 10, 2007, 11:06:02 AM »
Just remember they have different octane ratings in Europe.
Also does no good with higher rev limit if it's not making any more power up there. Very little room for error reving that high imo.
FYI, a friend is getting out of the aftermarket business and there could be a potential GB on aftermarket chip very similiar to Dinan's maps for $30-$40 possibly in the near future.
Gunni
ebay.de ecu chips
« Reply #7 on: January 10, 2007, 12:01:12 PM »
Ok I´ll re word the question
what´s the max revs the M42 can handle without valve float or any other issues?
I feel my M42 wants to pull all the way to the current 7k revlimit,
with a turbo I could easily make that even farther
e9nine
ebay.de ecu chips
« Reply #8 on: January 10, 2007, 12:12:16 PM »
Gunni your question was clear before - my post was more generic and you're in the " :cool: " category as you have some modifications to the motor. I personally wouldn't get it to rev too much higher without the right recipie on stock internals. Based on what I have seen (and I don't profess to be an expert) the recipie for high revving durable engines involves a lot more than most say i.e. cams, headwork and tuning.
It would be awesome to have a turbo car like yours with a mostly stock internal configuration as a stock comparison basis prior to doing any extra work in search of more power.
« Last Edit: January 10, 2007, 01:29:38 PM by e9nine »
Gunni
ebay.de ecu chips
« Reply #9 on: January 10, 2007, 01:01:31 PM »
well it´s not turbo yet,
by revving higher I need less boost to make higher hp,
I´ll probably just keep it at 7200 since some chips are like that,
I have 0 plans to mod it any further,
I start hopefully, automotive engineering in 8-9months in another country.
so I don´t have alot of time for this and well I still have two S50´s lying around and I´d like to put my money and efforst towards them, if I wasn´t going
