Author Topic: Washer Pump Power  (Read 2963 times)
Slowered318
  • -Receive: 9
    • My '91 318is
Washer Pump Power
« on: April 11, 2014, 12:09:26 AM »
Can someone with a multimeter do me a huge favor?
I'm getting 12 volts on both the purple/black and brown/black wires at the washer pump, it doesn't seem right but it could be normal? In the middle or replacing all the headlight wires from the fuse box forward, I want to know if I have shorted something out in the process.
Re: Washer Pump Power
« Reply #1 on: April 11, 2014, 10:19:55 AM »
If it stops raining I'll put a DMM on mine.
Looking at the ETM, I'd bet 12VDC on both sides means a damaged wiper control relay. But that wiring is a bit odd, like a lot of E30 systems. Did you try jumping the pump directly?
Slowered318
  • -Receive: 9
    • My '91 318is
« Reply #2 on: April 11, 2014, 12:40:56 PM »
I haven't hooked up the pump or put any load on that wire yet, don't want to damage the relay. The fact this circuit has a 30 amp fuse and 18 or 20 gauge wire already concerns me a bit
When I discovered this I immediately cursed and ran for the battery terminal. lol
« Last Edit: April 11, 2014, 12:46:35 PM by Slowered318 »
