Author Topic: Anyone want a 2.3 l m42  (Read 7419 times)
Darky
  • -Receive: 23
« on: February 20, 2014, 01:51:39 AM »
I saw this and thought that we might discuss it.
It would probably have a stroke in the order of 96-98 mm with 86.5 mm pistons.
So out of square, but could be fun at 2.3 l
Made by hartge though, never seen it before.
Warsteiner
  • -Receive: 21
Re: Anyone want a 2.3 l m42
« Reply #1 on: February 20, 2014, 08:05:32 AM »
Here is the info about the 2.3L from Hartge. I also have the 2.1 info if anyone is interested.
Cheers,
~Ralph
Beeker1972
« Reply #2 on: February 20, 2014, 07:46:16 PM »
lengthen the block by putting in a block plate between the block and head
Darky
  • -Receive: 23
« Reply #3 on: February 21, 2014, 11:30:49 PM »
So it could have the same rods as the 1.8 l m42?
Cheers,
~Ralph
Thanks Ralph
I actually would like the info on the 2.1.
Also what are the rod length on the 2 models did they put a metal plate between both models?
2 head gaskets yuk!
I saw a 2.3 for sale they only wanted 5k.
There would be some disadvantages of having such a massive stroke though?
Thanks rohan
Warsteiner
  • -Receive: 21
« Reply #4 on: February 22, 2014, 05:55:06 AM »
Here are the 2.1 specs. I'm not sure what length rods they used. That could also be dependent on what type of piston they used.
Cheers,
~Ralph
DRTE30
« Reply #5 on: February 22, 2014, 08:35:12 PM »
Not sure if anyone is interested but while in Germany last summer and poking around I came across two pair of the Hartge 2.3L valve cover emblems.  I swooped them up for an arm and a leg to turn them around and sell them here in the US.  If any of you go through with this engine build, which would be a kick in the pants, lemme know if you want the final Hartge touch on your valve covers!
One has a protective tape on it, the other is missing the protective tape, and all are mint.
Beeker1972
« Reply #6 on: February 22, 2014, 10:23:31 PM »
If you live in USA I'm starting to think it's cheaper to do a M5x swap than build a 2 liter M42.
Darky
  • -Receive: 23
« Reply #7 on: February 24, 2014, 01:26:17 AM »
You would get really close with 86 mm pistons and m44 crankshaft though, both readily available!
Cheers,
~Ralph
Thanks Ralph
On closer inspection of your photos i see that they have bored the block to 87 mm and sleeved it!
There would have to disadvantages to having such a long stroke though? Would they use bmw oem parts for piston and rod?
Warsteiner
  • -Receive: 21
« Reply #8 on: February 24, 2014, 08:12:53 AM »
I have no idea how Hartge made those engines. Knowing them they used all there own parts.LOL
Cheers,
~Ralph
