DISCUSSION
Swaps, Turbos, Buildups
M42 build for E36 Compact
Pages:
3
4
5
14
Topic: M42 build for E36 Compact (Read 106405 times)
MrPhatBob
-Receive: 7
Re: M42 build for E36 Compact
Reply #30 on:
January 21, 2014, 02:02:31 PM »
I measured the lifters from the M42
Diameter: 34.99mm
Height: 26.00mm
Foot depth: 13.97mm
They show the same lifter specs for the 8V
http://www.ebay.co.uk/itm/Audi-VW-1-6-1-8-2-0-8V-racing-solid-lifters-cam-followers-tappets-set-8pcs/121178191705?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D286%26meid%3D4280270231920223192%26pid%3D100005%26prg%3D1048%26rk%3D1%26rkt%3D2%26sd%3D111142281592%26
So that looks to be the same, what I don't know about is the lash caps that sit between the lifter and the top of the valve.
Oh, and I went to buy ACL bearings today - ACL have gone out of business so no joy there.
Last Edit: January 21, 2014, 02:07:36 PM by MrPhatBob
wazzu70
Nasty Nick
Hero Member
-Receive: 18
Reply #31 on:
January 21, 2014, 03:28:21 PM »
VAC sells lash caps, but of course its never the cheapest option.
Also make sure to determine if you have 6mm or 7mm valve stems
-Nick
91 E30 M42 with VEMS
MrPhatBob
-Receive: 7
Reply #32 on:
January 21, 2014, 05:08:44 PM »
6mm
colin86325
Hero Member
-Receive: 15
Reply #33 on:
January 23, 2014, 07:24:58 AM »
BTW, you might find this interesting regarding the EWP:
http://www.m42club.com/forum/index.php?topic=6419.msg121375#msg121375
MrPhatBob
-Receive: 7
Reply #34 on:
January 26, 2014, 02:37:13 PM »
Nice one Colin, I'll give that some reading tomorrow at work.
ACL Bearings have arrived
The next blight on my horizon are the oil squirters, I managed to loose a few of them in the hot wash (yeah I know, but they looked like they were press fit and that turned out not to be the case )
wazzu70
Nasty Nick
Hero Member
-Receive: 18
Reply #35 on:
January 27, 2014, 10:50:57 AM »
At least you realized you lost them. There have been MANY BMWengines put back together and run with a few missing squirters....and 0 oil pressure because of it!
-Nick
MrPhatBob
-Receive: 7
Reply #36 on:
January 27, 2014, 02:19:04 PM »
It was only because I was washing the block and admiring the jet of cleaning solution that was squirting into the cylinder, I mused for a while on what method of controlling oil pressure they'd employed - and that's when it hit me.
Its the cost of the bloody things that I find upsetting.
wazzu70
Nasty Nick
Hero Member
-Receive: 18
Reply #37 on:
January 28, 2014, 05:58:32 PM »
I can understand frustration at parts cost!!
Im very excited to see how your engine turns out!
-Nick
MrPhatBob
-Receive: 7
Reply #38 on:
January 29, 2014, 04:40:06 AM »
There are issues around feature creep with it... I'm drawing up a water pump blanking plate after colin86325's post.
The water jet cutters
http://www.h2oprofiling.co.uk/
have just texted me to say that my ITB to M42 head plate has been finished, so I'll have that to play with tomorrow.
MrPhatBob
-Receive: 7
Reply #39 on:
January 30, 2014, 06:07:33 PM »
I got my hands on the adaptor plate from H2O Profiling so I was able to start mounting the S50 bodies.
Cut three pockets to allow the M7 bolts to recess below the mating surface of the plate.
Cut four pockets 9.5mm dia 4mm deep, then tapped an M6x1mm thread to locate the ITBs on the plate.
thebrelon
-Receive: 3
Reply #40 on:
January 31, 2014, 06:47:48 AM »
is it the definitive intake runner length?
because all I could read on the subjet calls for longer intake runner to be able to tune the engine properly.
Vince
'91 318is 230000km stock
MrPhatBob
-Receive: 7
Reply #41 on:
January 31, 2014, 01:49:45 PM »
As I understand it the runner length is dictated by the length of the inlet trumpet, these ITBs normally bolt directly onto the head, in this case they're 16mm further from the ports than normal. I will consider my options for trumpets once the engine starts coming together better.
wazzu70
Nasty Nick
Hero Member
-Receive: 18
Reply #42 on:
January 31, 2014, 02:06:18 PM »
Yeah, runner length includes the ITB assembly and trumpets. The trumpets are not shown in the picture.
-Nick
MrPhatBob
-Receive: 7
Reply #43 on:
January 31, 2014, 04:34:54 PM »
Currently I have some velocity stacks from some Weber 45 carbs, they'll not be long enough to make much torque, there are options around, but the standard M3 ones should be plenty good enough
thebrelon
-Receive: 3
Reply #44 on:
January 31, 2014, 06:00:47 PM »
I learned something. thanks guys!
Vince
Pages:
3
4
5
14
DISCUSSION
