Its been a while since the last update - but thats not to say nothing has been happening...
The ZRP Rods arrived - weighed at 534.5g (OEM weighed in at 547g) 12g saving - totaling in a saving of 68.1g per cylinder when adding the piston mass.
The block was chemically cleaned, so it needed a spot of paint to stop things rusting.
Next up - mains clearancing with Plastigauge - torquing down the caps to 60nm.
And then pulling the caps off to measure the spread - and the results were good! Close enough to 0.050mm on every journal.
So as thats good we need to see how the piston/rod combo works out in the block.
Leveling the piston using the magic tool means I can safely measure the piston to deck distance.
Then repeating the same measurement using the same piston and rod assembly at the far end of the block.
Result @TDC cylinder 1: 0.0476" above deck. cylinder 4: 0.0465" above deck. So I'm going to have to grind the deck flat.
For my metric users out there the piston was 1.32mm proud of the block, which I expected to occur because the compression heights differ in the S50B32 and M42 pistons... And it reminded me why I'd bought the 11.5:1 JE pistons - once machined flat I'm going to be sniffing around the 12:1 compression ratio (if my maths is right - and it seldom is).
Next up I need to check the valve pockets for clearance, so get TDC sorted with the degree wheel.
I didn't photograph measuring the valve depths - because it was hectic, I know, its wrong, but we need to be grown-up and learn to cope with disappointments in life...
Inlet clearance:
12deg ATDC => 4.31mm
20deg ATDC => 6.32mm
Exhaust clearance:
12deg BTDC => 1.50mm
20deg BTDC => 3.47mm
So far so good - its looking like my compression will be close on 12:1 and I can run some aggressive cam profiles.
We were comparing this engine with the Cosworth BDG engine which one of the engine builders used to build at Cos. they made 212bhp from a 1.6litre engine. Similar bore/stroke combination, exact same rod ratio, similar valve angles, same compression ratio... Its nice because I'd like to make 200bhp from this build, the possibility that I could make it is what drives me...
