Author Topic: little screws for the butterflies in the TB  (Read 2113 times)
irish44j
« on: November 15, 2013, 07:32:27 PM »
Disassembled the TB completely to do a refresh. Looking at the little screws on the butterflies (that hold them to the shafts), they almost look to be mildly mushroomed at the base of the thread (essentially, a lock-screw). When removing, looks as if the last thread on the screw pretty much just shaved itself out (these things are TIGHT).
I don't see those screws shown anywhere on RealOEM or elsewhere as a standalone part. Any advice on putting them back in/replacing them? At this point it looks like I'll just chamfer the edge a bit and use some red loctite, but would obviously like to "do it like the factory" if possible.
wazzu70
  • Nasty Nick
  • -Receive: 18
Re: little screws for the butterflies in the TB
« Reply #1 on: November 16, 2013, 06:28:12 PM »
I think uour best bet is to reuse the screws and use loctite. They aren't intended to be disassembled from the factory point of view.
A lot of times its a really fine thread pitch too so no normal fasteners work as replacement!
-Nick
91 E30 M42 with VEMS
« Reply #2 on: November 19, 2013, 06:48:56 PM »
They're staked to prevent them falling down the intake. I'd probably reuse mine with some Loctite red, since they don't get very warm.
I'd suspect you could order them from a supplier like Grainger, but I'm not sure of size. I'd bet they're a common metric size.
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #3 on: November 20, 2013, 01:24:11 PM »
Dave, the BMW ones might be a common size but I know VW and Porsche are not a common size. I assume BMW would be similar.
Your best bet is to reuse the fastenets!
-Nick
bigskyis
« Reply #4 on: November 20, 2013, 02:01:13 PM »
I could be dead wrong on this account but those screws are installed and staked as they are not a serviced item. Your best bet and (safest) path of least resistance is another complete throttle body. And leave the screws alone on the next one.
