I have been chasing a slight coolant leak since I took ownership of my 318is about three years ago. Ever since I did the "Mess Under the Intake" clean up, I have had this leak. I am generally losing about 1/3 cup every two weeks, measuring from the cold water line on the expansion tank. Though, it is not too terribly much in coolant loss, there shouldn't be any loss at all. What's worse is that I cannot visually see this as the engine is running and up to operating temperature. This has me thinking that it is slowly boiling off and cannot be visually seen as a drip or condensation somewhere- or worst case and the head gasket has gone bad in a non critical spot.
Finally having the time to chase cooling/heating and AC issues, I got the motivation to call up a local auto parts store to rent a coolant system pressure tester. A quick side note, if you've spent any length of time living in Hawaii, you will be familiar with how brain dead the general population is. Before I drove down to rent this tool, I had three different employees verify that they had a tester for a BMW on hand. Ok, great...I'll be right there. I picked up the tool, and drove home to find that it doesn't fit and in tiny little print it states that the adapter is for GM cars only. So I call the guy up and tell him, and he replys "Sorry brah, no can. We no have any ting for BMW. Nevah have". Well...I guess that's life.
The next option was ordering a kit through Harbor Freight. It's originally $120 and some change, but currently on sale for $74. Though, the reviews for the kit are mix match and everyone complains about how brittle the adapters are. Also, I don't need a ton of different adapters. Lastly, this is a tool that will rarely be used, so the cost outweighs the means. I finally settled on going to the junk yard where I picked up a radiator cap. I brought it home, drilled a hole straight through the center of it and inserted a schrader valve from an old beach cruiser bike tube, then epoxied around the valve and feathered it out. It took all of five minutes to complete and I will give it a go over the next few days. I have included pictures of the final product.
Items needed:
Radiator Cap
Schrader or presta valve from bike tube
Razor blade or utility scissors
Drill with various bits
Chanel locks, vice or vice grips
flat end screw driver
silicon epoxy or 2-stage epoxy
bicycle pump w/gauge
air pressure gauge (if not built into pump)
iced coffee (in my case) or beer
1) Begin by securely fastening the radiator cap such that the center mechanism with the two o-rings does not spin freely.
2) Use a small diameter drill bit as a pilot hole, and center the drill bit on the cap and drill straight through until it pokes out the other end*.
3) Continue stepping up in drill bit size until you are satisfied with the hole needed on the top of the radiator cap to properly insert and secure your bike valve.
4) Rough up the surface of the radiator cap with sand paper to give your epoxy something better to adhere to. Clean and let dry.
4) Prepare the bicycle tube valve by cutting it off of the tube BUT leave material around the valve.
5) Trim the rubber around the valve such that you have a circular flap/gusset.
6) Take your valve and your flat head screw driver and push your rubber gusset into the hole you drilled at the top of the radiator cap until it is completely in place.
All of the rubber gusset should be pushed inside the hole, the valve should be poking straight out, and the two o-ring center should spin freely.
9) Next prepare your epoxy and apply as you see fit. Be mindful to take something flat and work it into and around the base of your bicycle valve to mitigate any air leaks. Wiggle the valve around as well to work in the epoxy as best as possible.
10) Follow the instructions per your epoxy of choice and let fully cure.
11) Admire your handy work, open your beer and boast to your wife/girlfriend about your cool contraption and all the rad things you can do with it.
12) Once cured and you're ready, install the cap, connect pump and pressurize the system to the OEM specification for your system**.
13) Look for leaks. It may be obvious; it may not. It may involve removing your lower dash to access the interior heater core and plumbing or it may involve getting under your car to look for drips. Worst case if you have exhausted all coolant connections, you pull spark plugs and look for coolant seeping into the cylinder(s). Oh Duh moment: Everything could be fine in your system and you are certain of this yet don't know where else to look: the radiator cap you are using may no longer be effective and needs to be replaced.
*You may not need to drill completely through the center of this piece (see last picture) as this mechanism isn't entirely air tight. I did it to allow air to pump more easily into the system.
**Do this incrementally and check your pressure. It is in your best interest to not over-pressurize the system. Use a digital gauge like I have, if needed.
