BMW OEM E30 Alarm
Author Topic: BMW OEM E30 Alarm  (Read 5077 times)
DRTE30
BMW OEM E30 Alarm
« on: July 07, 2013, 09:00:32 AM »
Greetings,
I'm here in Germany looking at an original E30 alarm system to purchase second hand.  The part number for reference is: 82119418333.  This part number shows that it is only good for European E30's.  However, I'd like to know if anyone out there may have some first-hand knowledge on adapting this "Europe only" alarm into my US 318is?  I am trying to search around the internet for other information, but cannot come up with anything.  Other than maybe a few subtle differences in the ECU, I don't see where would be other problems with the wiring.  I would like to assume that BMW would make this as plug-and-play as possible.  Any guidance would be appreciated.
Re: BMW OEM E30 Alarm
« Reply #1 on: July 09, 2013, 04:15:42 PM »
I know I have the US version in a box somewhere, nearly complete.  I pulled it from a '91 325i.  I don't have any idea of specifics, but they seem pretty standard.  IIRC, this one had two relays.  If I had to hazard a guess I'd say one cut the yellow/black starter wire from the key switch and the other cut the fuel pump feed wire.  Likely it also used a few internal transistors to unlock the doors, beep the horn, etc...  It had a few sensors, thin ribbon wiring and was installed above the glove box.
I couldn't test it as it had no remotes.  Pretty sure it's the Alpine version?
If I can find it I'll snap a few pics or get that part number.  From what I recall, the wiring was kinda/sorta OEM.  I'm sure it was spliced in as a dealer installable option.
DRTE30
« Reply #2 on: July 20, 2013, 08:56:43 AM »
Dave,
Thank you for checking.  The one that I am looking at here is the Alpine version as well.  I don't forsee any drastic differences in the ECU harness from the US version to a European version E30.  Aside from some lighting differences because of TÜV standards to DOT standards, the rest of the wiring should be straight forward.  Unfortunately, I don't have the means to check the wiring of this alarm in person- the sale is on an online German forum only.  I suppose I could purchase it and give it a shot with installation.  Thanks again for the reply and I look forward to your update.
2ruble
« Reply #3 on: October 27, 2013, 01:09:16 PM »
in the e30 I recently purchased there is a factory/OE alpine bmw alarm... yet, there are no remotes for mine either. Is there a way to tell what all the thing is capable of? ie - cutting fuel, keyless entry, etc.
Do they have a tendency to stop working? If not, where can I get a new FOB? lol I would love to utilize factory equipment
« Reply #4 on: October 27, 2013, 02:02:50 PM »
I've had bad luck with them.  IMHO they were underbuilt, transistors tend to die over the years.  Mine had a fuel cut relay and an ignition immobilizer that was signalled by door locks, a tilt switch and what I think was an impact sensor.  No key fobs came with the car.  It originally had large, ugly square key fob remotes.
2ruble
« Reply #5 on: November 02, 2013, 05:21:47 AM »
well awesome... lol - guess I'll put that out at some point... or just leave it since I put my glove box back in yesterday... we'll see about getting something new and simple... Thanks
