Author Topic: getting to oil filter housing gasket?!  (Read 5153 times)
///m42 sport
« on: December 08, 2012, 11:00:59 AM »
about to replace the gasket, but looks like a pain the in ass to get to.  removing the alternator, bracket etc...
monty23psk
  • -Receive: 17
« Reply #1 on: December 08, 2012, 11:03:13 AM »
yes alternator needs to come out to gain access to long bolt that is reachable from inside alt. bracket
deansweet
  • -Receive: 12
« Reply #2 on: December 08, 2012, 11:36:30 AM »
yep.. not really hard to do, just time consuming...
bme30
« Reply #3 on: December 08, 2012, 11:54:48 AM »
I did this 2 weeks ago... Here are some pics..
And here is the old O ring
Cracked when i took it off
No more oil leak :)
Took me about 2hrs
Good luck
///m42 sport
« Reply #4 on: December 08, 2012, 12:28:02 PM »
cooll thanks those pics help.
i'm doing the upper oil pan gasket at the same time...hopefully taking care of the majority of my leak right now.
« Reply #5 on: December 08, 2012, 03:15:36 PM »
It isn't too bad to replace.
Do NOT just use the paper gasket, though. Get some Permatex Ultra Grey silicone RTV. Clean the filter housing and timing case gasket surfaces with some alcohol to get all of the oil off. Then apply a small amount of the RTV to both of these surfaces and spread it into a THIN coat with a finger. I also recommend putting a small amount of silicone dielectric grease onto the rubber O-ring so that it will slide in easier. Also clean out the circular port in the timing case, and do not get ANY dirt in there or it may end up in a main bearing.
Put the gasket onto the timing case, align it and then carefully put the filter housing on, using the circular oil outlet to get things aligned. Push it on firmly, and don't twist it or the RTV will get messed up. Slowly tighten down the screws from the middle and then out to the corners, 1/4 turn each at a time alternating until they are all tight. This will ensure that the RTV squishes evenly. If you just fully tighten one down and then the others, it'll probably bend & crack the filter housing. RTV does require this whereas a plain paper gasket does not so much. Let it sit for 24 hours so that the RTV can cure before being put under pressure.
Key note: Do NOT get ANY RTV in, around or near the circular thing. That is the clean oil outlet, and if RTV gets in there it could end up in the engine. Metric Mechanic told me that a customer once got a big blob of it in there by accident, and that it made it into a lifter port, causing the lifter to not function. Be very careful and check everything twice before assembly!
« Last Edit: December 08, 2012, 03:17:55 PM by bmwman91 »
deansweet
  • -Receive: 12
« Reply #6 on: December 08, 2012, 04:49:43 PM »
Yep! That's how mine looked as well.
« Reply #7 on: December 08, 2012, 05:02:39 PM »
I heard that paper gaskets were OK as long as you used some Hylomar or other non-silicone sealant.  I heard Permatex reformulated their version, haven't found a comparable product yet.
Here's the stuff:
http://www.roverparts.com/Parts/901.cfm
...if they're selling it to keep oil inside English iron, how could it fail to work for our BMWs?
I might also try Hondabond.  If it'll preserve the paper gaskets on those old Jap bikes I'm sold.  I hate when those tear - they're expensive.  Unfortunately they're also required...the seal thickness on side cases is cannot vary.
« Last Edit: December 08, 2012, 05:15:54 PM by DesktopDave »
bme30
« Reply #8 on: December 08, 2012, 05:04:52 PM »
I got the O-ring and gasket from bmw... Imo just get it from there and not worry
///m42 sport
« Reply #9 on: December 09, 2012, 09:35:24 PM »
well I replaced the oil pan gaskets,  upper and lower, and oil housing gaskets with help of friend.  4-5 hours on jackstands. not hard just takes alot of time.  I used the paper gaskets along with rtv. letting it sit overnight to fill with oil.  fingers crossed
///m42 sport
« Reply #10 on: December 15, 2012, 03:53:26 PM »
bone dry!!!
bme30
« Reply #11 on: December 15, 2012, 04:02:29 PM »
Nice!
deansweet
  • -Receive: 12
« Reply #12 on: December 15, 2012, 09:27:37 PM »
very nice!
Worth every minute, eh?!
