Author Topic: My First M42 (dyno inside)  (Read 5510 times)
Dricebrug
« on: March 06, 2013, 02:56:14 AM »
Posted twice!
« Last Edit: March 07, 2013, 03:09:28 AM by Dricebrug »
deansweet
  • -Receive: 12
« Reply #1 on: March 06, 2013, 08:53:29 AM »
another empty thread?!
Warsteiner
  • -Receive: 21
« Reply #2 on: March 06, 2013, 09:26:32 AM »
I know....I was getting excited that people would start posting some dyno charts of their chipped, stand alone or stroker motors!!
So why don't we fill this thread with all those??
Cheers,
~Ralph
Dricebrug
« Reply #3 on: March 06, 2013, 08:09:26 PM »
Hmmm.... Not sure why the original post is gone :confused:
Recently I purchased a 91' 318i with 150k. The previous owner was very upfront and said he believed the head gasket was bad.
After getting the head off, I quickly realized that the head was infact cracked. Luckily however, I had a spare M42 head.
Taking both heads to the machine shop, here is the list of what was done:
- The valves where used off the E36 M42 head vs. the E30 M42 head's 7mm valve stems. (Thats 12g PER VALVE of weight savings)
-Even with the lighter valves, I used the dual spring setup off of the E30 M42 head. (even tested against the conical s52 springs, they were stiffer!)
- .020" was shaved off of the head for a little better compression.
- I had some minor port work done. (Mostly bowl blending and smoothing everything out)
- Lastly, once I had it up and running again, I threw in a Mark D. tune.
Here is the car as it sits today:
Here is one of the intake ports after port work:
And finally, here is the dyno graph from today (~40 degrees out)
I am happy with the power, considering its a stock motor with minor touches. Having that been said, I have full access to a dyno and would love to move some power up top.
I am open to all suggestions, and I will dyno test them!
Dricebrug
« Reply #4 on: March 06, 2013, 08:10:15 PM »
Showing up for me now!
e3091318is
« Reply #5 on: March 07, 2013, 03:27:19 AM »
That is pretty good that you are getting factory power from that!  I have a used engine I bought from a wrecking yard.  M42 off a 1995 318i.  About 140k miles.
2000 Mercedes S500 (Sold)
2001 BMW 325CiC (Sold)
2003 Honda Accord Coupe EX-L V6 (Sold)
2001 Audi A6 2.7T (Sold)
1984 318i Coupe (Sold)
1991 318is Coupe (Current Project)
Dricebrug
« Reply #6 on: March 07, 2013, 05:45:34 AM »
Quote from: DrJeremy28;120762
I'm not sure if the M42 is under/over rated, but with a claimed 134hp and 127ft/lbs stock, if you use 18% drivetrain loss, that puts my little M42 at 162hp and 150ft/lbs at the flywheel. Not too too bad.
carnurd
« Reply #7 on: March 07, 2013, 11:55:51 AM »
My M42 with +1 SS valves and cams made 142rwhp @ 2600ft elevation 90deg ambient temp, same torque though of 128.  But looks good I wish I had a lot of head work and i know that number would be way higher.  The main issue I run into is that I'm severely choked down by the intake manifold, my car loves to breathe at RPM and so from 5800rpm-7.5k it just hits a wall, shows up on the dyno graphs.
Dricebrug
« Reply #8 on: March 07, 2013, 06:19:06 PM »
Quote from: carnurd;120775
From what I can see, there is absolutely a flow restriction causing the top end to fall on its face.
Oh well, it makes decent power for what it is. I may mess with cam timing a bit, but you can only do so much with limited air flow.
