Author Topic: M42 Turbo Oil Return Line  (Read 11709 times)
dmnracing
  • E36 Driver
Re: M42 Turbo Oil Return Line
« Reply #15 on: June 25, 2013, 08:51:34 PM »
We installed the inlet farther back in the block in order to allow the oil to cool against the pan as it ran down to the sump.  It was also above the sump level.
That makes sense, do u also run a oil cooler or use that technique instead? Also where did u choose to get the oil feed line from?
"DANGER TO THE MANIFOLD"
fumstoo
« Reply #16 on: June 27, 2013, 01:24:19 PM »
theres two spots on the oil filter housing. One in front with a 6mm(iirc) allen bolt in it and one in th eback where the stock oil psi sensor goes.
dmnracing
  • E36 Driver
« Reply #17 on: June 28, 2013, 03:57:17 PM »
 Is that the same on the e 30 and the e36?
