Author Topic: Trunk storage tray question  (Read 6324 times)
monty23psk
  • -Receive: 17
« on: March 03, 2013, 09:53:12 PM »
My car came with storage tray accessory above the battery tray. I can't find any info under the ETK/RealOEM for the BMW PN: 72601929409  which is listed on the underside. I want to know if there is a clip that connects the tray to battery cover as they both have a hole in the middle. This is a longshot but maybe someone knows the answer.
TIA
keflaman
  • -Receive: 35
« Reply #1 on: March 04, 2013, 05:10:51 AM »
I don't have the exact answer you're looking for, but after rooting through my 20-year bin I used a nut plate similar to this http://www.ecstuning.com/Search/Nut_Plate/ES74224/. It took a little trimming of the hole, but it works.
monty23psk
  • -Receive: 17
« Reply #2 on: March 04, 2013, 06:49:33 AM »
Cool, that's one option.
romeomike
Re: Trunk storage tray question
« Reply #3 on: August 09, 2013, 09:23:39 AM »
Hi:
The connecting part for the two tray halves is made of metal, black rubber and hard white plastic, and is 7/8th inches in length. At the top of it is a slot for a screwdriver to turn it to expand the rubber section and hold it in place. I should have enough time on the weekend to take a picture and post it.
That being said, I don't have it hooked up in mine. As long as I don't flip the car over, gravity and friction hold the upper tray in place quite nicely by themselves.
« Last Edit: August 10, 2013, 03:48:29 PM by romeomike »
monty23psk
  • -Receive: 17
« Reply #4 on: August 09, 2013, 02:26:46 PM »
Thanks.  A pic would be nice to see what it looks like for my curiosity. But with the new battery tray I bought, no hole was there. I guess not to many flipped in the past that they required to keep the lock...lol.
romeomike
« Reply #5 on: August 10, 2013, 03:48:49 PM »
Link to the picture, as the embedded image requires too much scrolling for my taste.
http://imageshack.us/photo/my-images/199/c1b5.JPG/
monty23psk
  • -Receive: 17
« Reply #6 on: August 10, 2013, 09:43:51 PM »
thanks. Would have never thought it looked like that. The biggest with this part is the rubber as it needs to seal the hole. You dont want a liquid falling from the top onto the battery. That is my guess for it.
DRTE30
« Reply #7 on: August 10, 2013, 11:50:26 PM »
Happen to have a part number for that bolt?
Also, it looks like it's sealing and pinching at the same time.
