Hi everyone
As i said in an another post, i'm looking to build a little N/A M42 for my 318is e30
I have been thinking on 2 different simple setup
First setup is to use M42 crank with 86mm bore S50b30 pistons (but haven't find them yet) to make a 1881cc M42 with higher compression ratio.
this avoid a lot of work, only things to do is bore the block, change rod bearing and M44 head gasket as I know.
Second setup is to go with M44 crank and 86,5mm bore S50b32 pistons (already find them) to make a 1957cc M42 as I'm keeping the M42 head, but i don't know if the M44 head gasket can be use, also i didn't find a lot of information about M44 crankshaft. Engine is not going to revs past 7200rpm so there will no problem with the M44 crank right? the fact that is cast and not forged like the M42 one is really a problem on such a little N/A engine? I guess problem come with boost.
So if you have some ideas/answers/remarks about this two setup feel free to post
I also have an M47 crank but this involve much more manufacturing and i want to keep the engine a square one (bore > stroke) and don't go long stroke (bore < stroke)
All this will be going to power my stripped out 318is e30, with E36 gearbox and 3,45 LSD
Thanks in advance!
