Author Topic: S50b32 psitons with M44 crank  (Read 22937 times)
IlovM42
« Reply #15 on: January 16, 2013, 04:16:10 AM »
well euro S50b30 pistons bought, so project will be to build a M42 with 140mm rods ans 86mm S50 pistons :D
bme30
« Reply #16 on: January 16, 2013, 05:09:07 AM »
Whats the difference between s50b30 euro and us pistons?
accota
« Reply #17 on: January 16, 2013, 07:16:09 AM »
Quote from: bme30;119286
They're just different, ch, wrist pin, dome, ..., same diameter. Im not home so cant acces the info.
Enjoy the mahle online catalog:
http://catalog.mahle-aftermarket.com/product_catalog/modules/motorComponent/specs/index.xhtml?subId=4
IlovM42
« Reply #18 on: January 17, 2013, 03:23:43 AM »
you can find th eanswer here on another post
http://www.m42club.com/forums/showthread.php?t=17052
IlovM42
« Reply #19 on: January 17, 2013, 03:24:13 AM »
IlovM42
« Reply #20 on: January 17, 2013, 03:25:25 AM »
you can find the infos here
oups sorry for triple post, network problem
thebrelon
« Reply #21 on: January 18, 2013, 08:06:32 AM »
Quote from: IlovM42;119285
how are you going to fit 21mm diam wrist pin into 22mm rod small end?
Vince
'91 318is 230000km stock
bme30
« Reply #22 on: January 18, 2013, 08:21:41 AM »
I think the con rods he's using will have the right wrist pin and crank diameters
bme30
« Reply #23 on: January 18, 2013, 08:32:54 AM »
E36-italia
  • -Receive: 6
    • Motorsport-Media-Design.com
« Reply #24 on: January 19, 2013, 08:22:15 AM »
Quote from: accota;119115
Your next limitation must be the hydraulic lifters.
Not per se, you can rev the engine to 10K with hydraulic lifters... but not with the stock ones ;-)
The problem with our lifters is that the oil can't go out fast enough, buy them/modify them with a larger exit hole and you are in honda rev zone :P
I'd love to have a high revving short stroke 2lt M42.. it would beat the honda b16/B18 engines for sure.
ispierrot
« Reply #25 on: January 20, 2013, 04:06:41 AM »
The solution for cam lifters
http://www.youtube.com/watch?v=ynVBlDMow3k
ispierrot
« Reply #26 on: January 20, 2013, 04:07:25 AM »
accota
« Reply #27 on: January 20, 2013, 09:50:21 AM »
Quote from: E36-italia;119385
Hydraulic lifters to 10k? I wouldn't go over 7500 with the latem42/vw ones, which is already high.
Idk about drilling the lifters. if u starve the oil feed its a bigger mess.
bme30
« Reply #28 on: January 20, 2013, 06:47:03 PM »
Quote from: accota;119433
I think the metric mechanic hydraulic lifter upgrade will allow for higher rpm.  Not sure of their limit but for sure not 10k rpm.
IlovM42
« Reply #29 on: January 21, 2013, 07:42:06 AM »
Quote from: thebrelon;119353
you can change the bearing on the rod to suit the 21mm wrist pin
