Author Topic: my 318 is killing me right now $$$  (Read 9120 times)
« Reply #15 on: February 16, 2013, 05:31:47 PM »
I'd see if a hydraulic shop would do it too.  It's just a flanged pipe with nuts.  In a pinch I'd consider some rubber line secured with hose clamps until I could track one down.  It's not under pressure, I'll bet it'd last a while.
I might have one "in stock" - need me to check?
///m42 sport
« Reply #16 on: March 05, 2013, 09:58:04 PM »
Quote from: deansweet;120178
Me again...
Oh! and I just spent another $240 at Pelican for control arms, bushings and stabilizer bar links. Yeah me.
hah, i'm about to get control arms too!!!
deansweet
  • -Receive: 12
« Reply #17 on: March 06, 2013, 08:26:50 AM »
Quote from: ///m42 sport;120734
Where are you located?
If you are in the Dayton/Cincinnati I'd be more than happy to help out.
I bought a 22mm swivel head gear wrench that worked out nicely.
///m42 sport
Re: my 318 is killing me right now $$$
« Reply #18 on: March 13, 2013, 07:50:30 PM »
I"m in Muskegon Michigan.
Latest curse is the with the rain the other day and freeze overnight, the trunk lock went crazy and wont open.  That was essentially how I've been locking my car.  So after playing if the trunk lock for 45 min in the am deicing, spraying the shit out of it with lube, I gave up and unlocked the drivers door.
Then today, I was leaving work, and found out my battery died....And I cant get into my fucking trunk to jump the battery!!!!
colin86325
« Reply #19 on: March 14, 2013, 07:48:42 AM »
There's a terminal on the firewall in the engine bay that you can use to jump the car.  Sorry to hear :(
deansweet
  • -Receive: 12
« Reply #20 on: March 14, 2013, 08:00:00 AM »
I do not know what is the thread there but you can try hydraulic shop so they probably can produce you one. Try also official BMW dealer.
MW Dealer and they gave me a discount so just ordered it and the clip to hold rear half shaft not on hub for $42.
http://www.m42club.com/forum/index.php?topic=17472.msg120887#msg120887
///m42 sport
« Reply #21 on: March 14, 2013, 08:56:29 AM »
what does it look like?
///m42 sport
« Reply #22 on: March 17, 2013, 08:42:59 PM »
So got things sorted out this weekend w help of mech friend in a heated garage.  Being in heat made a huge difference and a whole lot less cursing.  Sprayed all the gunk out of the rear trunk latch...there was a ton of it. Got it working again.
Hoping this is the upswing on this car.  We completed the clutch and brake lines and rotors recently. Diagnosed a nonbleeding passenger front caliper. Seems to be driving great again now.  I love this car again. haha
deansweet
  • -Receive: 12
« Reply #23 on: April 20, 2013, 07:01:25 AM »
and now add a replacement alternator to the list on the 318is.
Took the bad one to Autozone and I have never seen an alt fail so quickly on their machine?!
It spun up for maybe 15 seconds before it went all FAILED.
Guessing rectifier? I might try to rebuild it?
I had a spare and it tested fine and I picked up another spare from Spyde25 that's on its way.
« Last Edit: April 20, 2013, 07:07:36 AM by deansweet »
